Ok guys this past season I was getting some bad oder from my holding tank I was noticing the smell was very strong in my engine comaprtment after someone flushed. after some investigation I discovered that the elbow vent fitting was loos on the holding tank afte trying to tighten it I discovered it is stripped I am also guessing the vent line is clogged or at the very least not providing aditquit ventalation. I would rather not replace the whole tank and would like sone ideas n how to fix my strpped fitting> i should als mention that my space to work in is very tight.
