I know that I started with a boat that smelled like a septic tank, shortly after I purchased it and it was closed up for 2 weeks I came in the boat with my wife and it was so bad we left. After taking her home I returned determined to find the cause and started investigating a wet forward bilge (near the head). There were 2 problems one gigantic hidden one, a leaking Aluminum holding tank combined with permiated original hoses and a raw water Jabsco.
When the tank was removed everyone helping the marina manager, his helper and myself all almost vomited there was about a 30" long stringer to stringer 1" thick "YELLOW" wet crystalized slick. The tank was removed and taken to a remote part of the marina to air out. The helper went scrambling out of the boat to the dock and dropped to his knees, both myself and the marina manager had tears in our eyes from the odor and us laughing at the helper fleeing! The front bilge was treated with straight Bleach and I got a scraper and plastic bags. Needless to say it was one of the most disgusting Mike Rowe jobs I have ever done. Eventually once everything was clean and dry the floor was removed and the entire front bigle was painted with Bilge Coat grey. Then the process of removing the old head, hoses, bilge pump well you name it I replaced it.
That is when I went to a freshwater flush system and new top qualiity everything. I have used a combination of Odorloss and CP. I have an inspection plate on the new 36 gallon Poly tank and I can tell you that if I don't use the Odorless within a week if I open the vent it would make most people sick. If I use the Odorless I can open the 6" inspection plate and there is -0- odor.
Kurt I am going to try the WalMart product.
