Honda Generator on SwimPlatform
Joeshoes
This is not the usual question on feasabilty. A lot of you put your Honda portable generator on the swim platform.
I would apreciate a foto of your setup back there. Some secure it to a crate etc.
Fotos please?
Dang it. I promised I'd post a pic of my 2000i on my swim platform quite awhile ago and never took the picture.. I'll do it next time out...So far we've been very happy with it's performance and fuel consumption (very low).. We just did two overnights used the AC, the fridge, electric stove, microwave, battery charger and watched 3 movies (not all at the same time) and used just one gallon of gas.. We leave it in eco throttle mode and let it ramp up the rpm's when it needs to. it is secured by two rubber cords looped through the swim grab handle. We haven't had any CO issues yet.
"We haven't had any CO issues yet."
Now that is a scary statement! Would you be ok with "we haven't had any bilge fumes yet"? I think not. I've seen a few of these secured on the bow. Seems that would prevent any possible CO issues from occurring.
Ahem; Our boat goes bow into the wind on the hook, I am very vigilant about CO. Seems to me the best location for the generator is on the swim platform as the wind would tend to carry the CO behind the boat. We do NOT run the generator all night and only for limited duration when the wind is calm. It's not for everyone but I think if you understand the risks and are vigilant, it can be done safely. I say we haven't had any CO issues "yet" because I am always expecting it in calm winds but so far the CO detector has not gone off
Only if you anchor from the stern.
When on the hook, the only place safer than the swim platform is if you put the gen in a small skiff tied off to the stern.
That is assuming there is wind; perhaps where you boat there is always a breeze to clear the air. In the CA Delta in the late summer and early fall, there often is no breeze at all. The air is very still and hot. A perfect time to fire up the genny and run the AC. I would be concerned using a portable genny on the swim platform under those conditions.
Are my concerns valid in the situation I describe? Also many many boaters in the Delta put put out a stern anchor to keep the current from swinging the boat parallel to the bank/levee.
That is assuming there is wind; perhaps where you boat there is always a breeze to clear the air. In the CA Delta in the late summer and early fall, there often is breeze at all. The air is very still and hot. I perfect time to fire up the genny and run the AC. I would be concerned using a portable genny on the swim platform under those conditions.
If absolutely no breeze, I would still feel safer with a gen on the swim platform than sitting on the deck. At least on the swim platform, it is completely outside of the boat. Sitting on the deck, I would expect fumes much more likely to get into the cockpit.
In the event of no breeze at all, running the gen would be done very sporatically.
I would never run a gen with the boat anchored bow and stern. Of course, I've never anchored my boat that way. Always from the bow.
Would securing it to the bow be a safe option? I have a fairly good sized pulpit and my windlass is out of the way; the anchor secures under the pulpit.
I run my 2000 on the swim platform also, living in Fl. if your not in the water it gets unbearably hot during the summer.
Joe i have a rubber mat under mine and also lash it to grab handle. anyway as to the safety issues i have two co moniters and never run it at night, i also have read too many stories about people going to sleep with generators of any kind then being found dead in the morning. really scares the begeebaa's outta me.
I have been hanging mine from the front rail above the anchor locker. Using the HD rubber straps creates no vibration at all. Have a CO dector in the cockpit and two in the cabin. Have never had any problems. Using my on board 5KW rafted up I have had the cabin CO dector go off before. But never with the Honda. Sure saves a lot of gas.
We were recently amazed at how many boats in the Bahamas have EU2000s. Hondas are turning out to be almost standard cruising equipment as far as I can tell. Of course, we all need to be careful with them. But I'd rather have my Honda running outside and away from my cabin space than an inboard running below decks any day of the week.
You feel safer running a non marine generator in a way it was not designed for than running a marine genset as it was intended to be run????????????????
I have my Onan water cooled Genny out of the boat now, doing some repairs. It usually mounts in the engine room and exhausts out the port side.
I have used it to run the A/C while on the hook on hot breezles nights. Now that it is out of the boat, I like the extra room in the engine compartment and the 170 lb less weight. I am considering a Honda Genny but not sure of best location to place it when in use.
If no breeze, will exhaust fumes drop?? Will they rise since the exhaust is warm??
Swim Platform?
Pulpit?
Upper station?
Put onan back in place?
I love this topic for many reasons. Safety is a big issue. A boat will turn on its anchor due to wind and current. If there is a third reason, clue me in. If the wind is very mild the boat will turn with the current. It is very possible that this little to no wind is opposite of the current. That would blow the CO from the swim platform into the boat. Very dangerous to say the least. Exhaust leaving the portable genny being blown back towards the cabin. I would not advise sleeping and running a genny. During the day you could account for this. At night while asleep you are at risk. Those who think marine generators are the way to go just because they spent thousands of dollars more need to reconsider things. The marine generator is not bulet proof. If so, then no CO detector would be needed. Many boats do not have a CO detector(s) unless a generator is installed. They do it because the marine generators emits CO and they hope the CO detector will sound off if something happens. By now Honda knows their generators are being used on boats. Is there a disclaimer or warning lable on them? No. They can be used very safely with a touch of common sense.
I have an older Yamaha generator, EF 1000, from about 1994. It was the quietest thing on the market back then. I got to hear one of the 2000 watt Honda's about a month ago. My 63db versus 58db. No comparison. The Honda was very quite. A couple of weeks later I heard the 3000 watt Honda on a house boat. Inside the house boat I never hear the thing running. I would recommend the Honda or a comparable Yamaha to anyone needing AC power. Just be sure to get a marine CO detector(s). Having power to cook coffee, recharge batteries, microwave, hot water, etc is a blessing. It makes boating more enjoyable.
I use footman's loops to secure my EU2000i but it is on the bow... you could use the same on the swim platform...
Works great!
I, like mandm1200, find this an interesting thread. This topic is visited frequently from a safety stand point.
We had a 38 ft SR and a large houseboat on Lake-O for many years; both had gen-sets that exhausted in the stern area. Is this CO any different than CO from a Honda?
Needless to say, we never swam near the stern of the boats with anything running, always watched and kept the kids away ….seems so common sense to me. I hate being in stalled traffic...
http://tinyurl.com/5pzlzr
Built in gen-sets can have their own set of safety issues.
As to topic, looks like a good attachment set up Go Aweigh.
The factory cover says "Honda Marine":
I don't have an issue with it. It sits between my two Honda outboards, but has much less exhaust. How much CO does this unit create when it only burns about 1 gallon every 6 hours?
Don't get me wrong. I understand your point and your concerns. Any internal combustion engine is dangerous. My personal preference is to keep such things on the outside of my vessel
Great point. Inboard gen-sets have to exhaust somewhere too. I've seen a few boats where the exhaust is amid ships, but most seem to be around or below the swim platform. And as your link shows, if there's an exhaust leak issue on an inboard, that's a BIG deal.
Be careful when using a generator on a swim platform. Just recently a Maryland boat owner was found unresponsive in the cabin. Investigation revealed a portable generator temporarily mounted on the swim platform with the exhaust facing the transon had melted a hole in the fiberglass thus permitted the exhaust to fill his boat with carbon monoxide.
The generator was being used to run the boats air conditioning unit.
