Went to turn on my hot water system and found that the water going in came right back out, I believe, through the bottom. The system was replaced new in 2003 based on a recall and I suspect the model they authorized was less than the best -- not sure of the brand/model yet, might be a Seaward.
After a little bit of shopping I noticed a big difference in price with the high end being Raritan, then Attwood and Seaward.
I don't have or need the heat exchanger so maybe that is the big difference in price. I think I currently have a 11 gallon Seaward so I will replace with similar capacity. Anyone have any recommendations?
I'm told the only difference between the marine models and the ones in Home Depot is silicone to seal the wires going through the housing to protect from sparks jumpin. Any thoughts on going this route?
Tim
Tim
