House or Boat
carver 2557
It's a bit out of my Pay Scale, but sure is nice...
Does anyone know it this thing is for real or not?...
http://survivaljournals.blogspot.com/2010/02/famous-french-shipbuilder-ship-company.html
Everything I have read indicates there is a full scale mock up only at this time.
http://www.why-yachts.com/pdf/CP_UK.pdf
It appears to be a solution looking for a problem. The designers see the problem as seperating some mideast prince from his money.
Wonder what the cruise speed and fuel burn is.
Main technical specifications
Dimensions & capacity
58 m length
38 m beam
2,400 tons displacement
12 guests
20 crew
3,400 m² living areas
Performance
12 knots cruising speed
14 knots maximum speed
Constant cruising speed up to Sea Force 4
Long range autonomy 4 Atlantic crossings
Promenade on deck 130 m long x 3 m wide
Swimming pool with thermo regulated water 25 m long
Green Energy
900 m² Thermophotovoltaic panels
2,000 kWh stored energy
Last-generation batteries (LiFePO4)
Renewable energy production 500 kWh/day
Lost thermal energy recovered 1,500 kWh/day
Annual equivalent fuel saving 160,000 liters
Crew of 20 for 12 guest, and a swimming pool!!
If one of the crew is a pool girl this may be the "solution to my problem"!
I'd be surprised if it ever gets built. It's ugly and impractical, where would you dock something with that sort of beam? I don't know how well it would handle rough seas either.
John,
You buy it, permanently anchor it in the Great South Bay, and you have a hell of a home with the best waterfront property one could imagine.
Also no property taxes, this is what I was thinking when I saw this.
Walter, the draft is 11.5', so you'll need to find somewhere else to anchor it :) But I could see that being the ideal use for it!
ITK, How can you say Pete's "pool girl is UGLY" we haven't even seen pic's of her yet?
