Earlier this season my Lowrance LMS-350A started loosing the bottom. When I leave my slip in about 25' of water everything looks fine. But once the depth drops to about 75' I start getting erroneous readings - like 1,000'+. I checked and clean all the connections, confirmed that voltage is 12+ volts and cleaned the face of the thru-hull transducer with a soft scrub brush – no growth on it before I scrubbed it). I called Lowrance and they said the transducer was bad – kind of sounded like the pat answer. They recommend that I buy a new transducer to confirm that old thru-hull transducer was bad and not the head unit. I asked about testing the transducer before I purchase a replacement and they said that there is no way test a transducer in the boat. Is that accurate? Is the only way to see if a transducer is still working properly is by using a replacement transducer?
