How Much Anchor Chain?
rfeeney
I have a Luhrs 29 sportfishing boat in San Diego. Boat weighs about ~ 11,000lbs. Am looking to replace chain and rode. Standard Westmarine package is 20 ft of 1/4 spliced to 200 ft 1/2 3-strand nylon. While I am rarely if ever out in bad weather, is 20 ft of 1/4 chain enough? Thanks....
"is 20 ft of 1/4 chain enough?"
No
Personally, I would go with all chain, but that is just me.
The last time I looked at prepackaged combination rodes the norm was 10' of chain. 20' is a lot better: not because of increased breaking strength but because the additional chain reduces the angle between the anchor and rode, improving performance of the anchor. 1/2" 3-strand and 1/4" short link should be fine for you. 200' of line is fine if you anchor in waters 25' or less in depth.
That said, I use 30' of chain on my 26' cruiser. There is plenty of wind in my area.
There are online places that will sell you ACCO or other quality chain cut to whatever length you want, swivels and quality 3-strand like Samson Pro-Set at considerable savings. Strangely enough, you can order chain, have it shipped across the country via ground and still save a lot over local stores. Some stores offer custom splicing if you want it.
Combination rode is a good choice on boats of this size. Chain will weigh around a pound per foot.
As said above, the weight of the chain keeps more rode on the botoom, decreasing the angle at which the boat pulls on the anchor shank. A good rule of thumb is to use a length of chain equal to the length of the boat. (I too use all chain but that demands a windlass)
Granted, that much chain is heavy and awkward to handle manually, but you are doing this to improve your holding power when it matters most.
Picture yourself suffering engine failure, near a busy channel, in rough weather, storm coming and daylight fading.
I have 75' of chain on my 30' boat (plus one of the 20' chain/rode packages as a back-up). My opinion is the more chain, the better (generally speaking of course).
One way to measure "how much" is: How much weight can you lift by hand? When the windlass fails, and you need to raise anchor, you will be holding the anchor, and most ( all ) of the chain while trying to retrieve it ( unless in very shallow water ).
Generally, the absolute min is one-half boat length. One boat length is nice. So is all chain. The point is that you want all-chain, but it is often impractical, due to weight. Therefore the compromise "mixed" rode. More is better up to the point that you cannot handle it for any one of several reasons.
It depends on who is answering the question of how much is reccomended. I always used the 1/2 the length of the boat as the rule until I spent a lot of time in the great lakes and started breaking my hold on the bottom regularly because of high winds. I soon learned that to increase holding power by adding chain was cheaper than buying larger anchors. I know that with 5/8" chain a foot added something like 8lbs so I gained 80lbs of holding power for each 10ft on the bottom. Having the right windless to handle the chain is a must!
"One way to measure "how much" is: How much weight can you lift by hand? When the windlass fails, and you need to raise anchor, you will be holding the anchor, and most ( all ) of the chain while trying to retrieve it ( unless in very shallow water )."
That about says it all. How much can you lift? As already given the best rule of thumb is a boatlength of chain is more than enough.
As a regular on the hook overnighter I have never had a problem with the boatlength of chain configuration even with another boat of equal size rafted next to me overnight.
I'm guilty of almost always anchoring in the shallows. It's very rare that I anchor in more than 4-6 feet of water. Where and how you anchor need to be factored in as well. I know those that anchor in really deep waters in the NW do things totally differently than I do.
That being said, if he uses the "1/2 of boat length rule", he's only going to need 14.5' of chain? That sounds like not enough to me.
Yep. I don't have an anchor windlass on the boat and 30' of chain plus 16 lbs. of anchor is a serious pull but most of the time I'm anchored in 10-15' of water. Having it in the water doesn't seem to make it weigh any less, either. Given a little more gray hair I may be cutting off five feet of chain or investing in a lighter weight anchor.
Seriously, you think pulling 30' of chain plus a 16# anchor is a serious pull?
LOL! Try it sometime without chain touching the rubrail or varnished toe rail.
You don't know what you're talking about. I just checked. 35' (not 30') of 5/16 BBB: That's 42 lbs. with the anchor that's 58 lbs. Plus you must exceed that pull for a short time to break free from a few feet of mud. No roller.
The Luhrs 29's have bowsprit with rollers as I recall, so that would help with 'lifting' the dead weight of chain and anchor. I can say lifting 45' of 5/16" chain and my Danforth type anchor clear of the bottom will put a little red in my cheeks, even with the roller on the bow.
IMHO, one boat length of chain would be adequate.
Then you are feeble, because dead lifting 58lbs is no big deal.
Whether someone is feeble or not is not the issue. KNOWING your limits is.
Some of us are still immortal, and invincible, some of us understand that that is the Kool-Aid of youth.
Back on topic: be sure that in an effort to achieve the most secure anchor rode, you do not exceed the parameters of all of the other components of an anchoring system. One of which is the "anchor wench".
20 feet is probably enough especially without a windlass. On ebay there are sellers who make these up and wiould put any lenght of chain you want.
all chain may be a little too heavy on a 29 footer. in that case, my rule of thumb is too use what you would normally use when anchoring with all chain... ex... if you usually anchor in 10' of water, then 50 to 60' of chain is a good start. if you anchor in shallow stuff most of the time... ex 6', then use 30' to 35' of chain or so. obviuously with a smaller boat, if you always anchor in deep water, you probably dont' want to go over 100' of chain.
a good amount of chain gives you so much faster setting and better holding that it's really worth the extra weight, unless you rarely anchor and/or rarely overnight.
personally i cna't imagine a boat without a roller...
Depends upon how young/old or strong/weak you are.
I certainly would not want to do that.
My 31' boat has 125' of chain. Some owner in the past liked chain.
George
