How much holding force is needed?
jmicklov
I"m planning to replace my rope windlass with a chain/rope combo this season. The boat is a 33' Sea Ray Sundancer and I figure most of my anchoring will be in fairly shallow water-rivers and currents with mostly a sand bottom. Although I haven't checked yet, but I suspect the existing wiring is probably #8 gauge that I hope to re-use.
I'm looking at 2 style windlass' one with 775 # pulling power that takes a 1/4" chain and 1/2" line- 36' class and requires #8 wire. The other is a 41' class that has 900# pulling power but takes a 5/16" chain and 5/8" line and #6 wire.
Both are free-fall devices with 80'/m and 75'/m retrieval speeds.
I'd like to go with the 775# windlass if possible, with about 10-15' of chain unless there are some compelling reasons to go with the higher pulling force. Thoughts?
The 775# pulling power is adequate for your needs. This saves you rewiring and lets you use a less expensive unit. I have a free fall with 30 foot of chain and 250 ft.of line on my 35,000 lb. boat and my 1000lb. pull is way more than adequate. Remember you are only lifting your anchor. Overkill is a waste of money.
since you aren’t supposed to use the windlass to pull the boat all you need to consider is the weight of the ground tackle.
Thankyou pdecat, but how often do you see a skipper slipping in & out of gear coming up on his anchor, letting the engine do the work?
everytime you see me :D
They are not designed to pull the boat so why burn them out unnecessarily? If you are pulling the anchor the engines will be needed shortly anyway.
More often than not I'd say. At least from what I've seen over the years. BYMMV.
With or without a windless you always pull up on the anchor with the boat engine/engines, if you know what you're doing, for many reasons, enough said.
I always pull up, because I always think about ? if I blow the breaker, it is in the ER, and not a quick trip to reset. We carry a little more chain than necessary for the Chesap, so I usually never get to the rope.
With wire that small I would guess you are talking about a Powerwinch windlass. I believe that most of the other windlasses out there would require a heavier gauge wire.
On my 33' Bert, I installed a SL 900FF. Following Lewmar specs required that I run ONE gauge wire as the round trip was about 70'.
Al
Is it possible to just change the gypsy?
Ditto bumping the engines to "chase" the tackle.
Thanks for the great feedback folks. Much appreciated.
Good call lobsta1. It was a Powerwinch that I was looking at.
Ironworks- Thanks. That's what I was thinking and it was nice to get an independent confirmation. About the windlass pulling the boat. Are you guys saying you're not supposed to retrieve the rhode by letting the windlass pull the boat toward the anchor? It seems to me you wound idle forward under power as you are winching in the line.
Jack,
If you are fortunate enough to have a good mate, or Admirable, they can stand at the bow and direct you port, starboard or ahead to 'bump' the engines in the direct of your rode. Idling in gear may be a little fast for the retrieval.
The windlass is NOT designed to "pull" the boat, only lift the anchor after having freed it from the bottom.
Side note, be sure to make secure the anchor line or chain to a cleat so as to not require the windlass to do the work of holding the boat in place while anchored.
Fred
+1 for using the engines.
I do have one exception, and I have a pretty big windless. If I'm lazy, single handing, and in no hurry, and there is no current, and I don't feel like walking up to the wheel. THEN I might pull the chain in a few feet at a time. Basically, you can take up the "slack" that is in the chain itself. If you stop when the slack is out, the weight of the chain itself will actually pull the boat forward as it resumes its natural parabolic shape in the water. Takes about forever though, but sometimes on a slow morning. I set the drag on the gypsy pretty light because its a real bear to loosen if you set it tight, so I don't have to worry about the strain level as it would slip anyways.
But...everyone else here is right on...you don't pull the full weight of the boat with a windless, you pull only the weight of your ground tackle.
Thanks Ghost and Freddy- good points. Having never used my existing rope windlass (for obvious reasons), these are great suggestions. Bumping the engines to increase the slack for the windlass is a great idea too.
BUT- you got me wondering now... is the "admirable" at the bow a typo or an intended word combo of 'admire' and 'admiral', meaning admiring the admiral (presumably one's spouse), who's standing directly in front of you at the bow :-)? That could significantly affect what direction and how hard you 'bump' the engines and how much you value your own life.
thanks again for the great ideas.
Jack, if the "admirable" is at the bow you want to either bump the throttle REALLY hard, or VERY VERY softly. Anything in between will result in a negative outcome. Choose wisely. This is an all or nothing game and you potentially have a lot to lose.
I also have a windless button at my helm. It's only one direction, up. I can pull the chain up, but not let it down from there. When single handing in a current I DO use that button while standing at the helm. You can retrofit pretty much any installation to have one too, its just a remote relay switch. The only problem with it, is that I can't see the direction the chain is coming off the bow from either helm, so you can't entirely be sure if you have the chain coming straight up, or at an angle. Still, it's not too bad. You can bump into gear, pull up 25 feet or so before not being sure where you are at. Just let the boat go back to neutral a few moments and repeat. I can kind of listen to the strain of the windless too. This is where having your chain or rode well marked that you can see from a distance is really important. Especially that last 25 of 50 foot depending upon your anchoring depth. That's when I come out from the helm and finish the job at the windless. You want to get the line/chain straight up/down without any slack. It will usually pull out by itself at that point with just a slight wave action, give it a moment to work itself. I've found being patient usually makes the job simpler. If it doesn't come out on its own, secure the chain and bump the engine into gear until you feel the boat break free, then go to the windless and pull it up the rest of the way. If in a crowded area, pull only to the water line. I can usually drag mine at idle without hitting the boat, which accomplishes two things. 1.) I can move the boat to where I'm not going to drift into anyone and then take my time to finish pulling up that last 6 feet and secure it properly 2.) The water action at the waterline will clean the caked up mud off my hook. Don't follow this blindly. It depends upon your particular boat as to whether you can do this without the anchor mucking up your gel coat. Mine is very reliable AT IDLE. Yours may not be.
Finally, dare I ask EVERYONE to take the time to FULLY secure that anchor into its choks. Mine sort of locks itself into the pulpit by the flukes fitting under a couple metal thingy's attached to the pulpit itself. I always tied a small line to keep the anchor from being able to move forward out of the chock. I thought that was enoough. However, I was taken by surprise last month when in heavy weather I found that quick little setup is only reliable for calm to moderate weather, four to five footers at most. Trust me when I say that when you see a 65 pound anchor get picked up like a peanut and start to get thrown around, you intuatively realize just how serious that situation is becoming. It's going to rip apart ANYTHING in its path. Also...I found that trying to wrestle a 65 pound anchor back into its chocks when singlehanding with 6 footers breaking over the bow is not for the feint of heart and there is no quick way to jettison an anchor attached to a bit of chain. You can't just go cut it and donate the smashing monster to the deep. Only option is to make sure it can't happen.
From now on, mine is going to get held in with some serious hardward and I really did not think it could come out from the way it used to sit. Friends....don't make my mistake. Make sure these things are really really held down firmly with a positive foolproof hold down on both ends of the shank. Those fluke thingy's are just not enough. I would have taken a picture but it turns out when TSHTF you don't have enough arms feet and hands on your body to do so while attending to the situation.
