My boat has a keyswitch to activate the macerator. The new RI law requires a locking Y-valve, regardless of whether the macerator is activated by a keyswitch or not. So I'm in the process of installing a Y-valve.
After cutting the 1.5 inch sanitary hose to length, I noticed that it slides on and off the Y-valve VERY easily.
I'm concerned, because a couple of years ago, when I replaced the original system, most of the hoses fit very tightly on to the fittings. In fact, I had to heat up some of the hose lengths and lubricate them in order to force the fittings into them - and even after heating, it was a struggle. Once the fitting was on, hose clamps seemed like just an added precaution - the hose wasn't about to slip off even without the clamps.
The installation I'm about to perform however, would apparently rely entirely on the hose clamps to hold the hose on the Y-valve. Without them, you could remove the hose with the slightest effort.
I'm just curious if this is normal (it doesn't seem like it is), or if maybe the hose I bought was out of spec and slightly larger in diameter than it should be.
