Hybrid Boat
Might actually work. Hate to think of the price tag, though.
Why not? The Navy ran diesel-electric hybrid subs for decades.
Wouldn't the weight of the add'l batteries onboard cost in fuel useage? It is my understanding that most hybrid cars are designed to transfer the energy of braking to generate electrical storage in batteries. Am I correct? How often does a boat "brake"? What do they use instead, super charged alternators or something?
Remeber when speed was calculated by small wheel at your keel? I'm sure a few of those could be engineered to do a pretty good job of rejuicing the bat-reez.
It's interesting.
I doubt the battery bank is all that big; and even if it is the new lithium batteries are much lighter than the lead ones we're used to (for the same power).
Regenerative braking would probably be useless on a boat, but you could run a much smaller engine with just enough power to cruise the boat efficiently; the added oomph to get on plane would come from the hybrid drive. Once on plane the same drive would pull off enough power to recharge the battery, same as with a car.
A paddle wheel would just add drag...
The electric boat that was pictured was completely electric. No gas. Top speed 7 knts.
I couldn't find a hybrid
I got a glimpse of something on a Science channel recently. Its a wind generator that looks like a Sail Mast.
Remember the Costeau family had a Sail boat with a large thick Mast that was really a sail?
Well this thing looked like a Costeau sail only it was a Electrical Generator.
That big sail Generator could be used to charge those batteries while you were at anchor or drifting (Fishing)
Esthetically it would look like a big smoke stack. Like you had a Steam engine down in the hold somewhere.
The same Science channel also went over those new Lithium Batteries Willie mentioned. They are amazing.
Also in the offing is a new generation of Solar Cells, produced in the form of Mylar strips. Those strips react to different light frequencies so they charge equally in the changing sunlight rays and on cloudy days.
Supposedly they are lighter, more powerful and a helluva lot cheaper than the earlier Solar Cells.
I saw in a boating magazine a few months ago where a boater bought a used Seimens diesel/electric system out of a city bus and put it in a 42 ft. trawler. He used a 20KW generator to run it and if it went down, he could use the 8KW house generator to run around 4 knots. When the main generator was running, it supplied enough power for both propulsion and house use.
I gave the magazine to the guy who runs the fuel dock where I get my gas. We traded magazines, his had an article about hydrogen powered boats of the future. Plenty of fuel source(water) under the boat.
Edit: It was a used system, but it was half the price of two new engines.
If I ever decide to go to trawler style and I had plenty of money, I really like the idea of diesel/electric. Seems like a great way to go and as said above, the house genset gives a good back up.
vision boat works has a hybrid. it is a diesel genny that runs a charger to recharge the battery bank. the genny also could power teh optional air conditioning.
"Hybrid boat"... Isn't that just a motorsailer or rowboat with an o/b?
I don't see the Frauscher vessel saving a lot on fuel, and that may not be the point, but then if the owner pays $150K for a Euro-slick 18'-4 1/2"(?) boat, he/she may not really care. Perhaps another expensive step towards a small relatively quick boat that actually is much more economical to run, though.
I have a neighbor that rebuilt a saillboat and rigged the prop when under sail to run a generator to charge the batteries.
That's a not-unusual solution to battery charging on sailboats. When I had mine, I had a rail-mounted generator that was driven by a prop on the end of 30' of line. It worked quite well, but the drag was noticeable.
On twin engine power boats, just remove the gas engines and replace with electric motor drive on one side and prop-driven generator on the other . Voila! Perpetual motion powerboat! Keep the sails and oars handy....
If it did work, you would be moving in circles..
