Hydraulic brakes help!
rayp
Hi,
I was hauling my boat to a shop last week. I felt my brakes weren't working and when I got there I noticed oil on the R tire but it wasn't coming out of the bleed valve. I am not an expert on this matter atall. Is it possible that my wheel cylinder is gone? or is there a simpler problem? Should I have to replace my brakes shoes now that they might got oil on them? Should I get the whole brakes kit with the new wheel cylinder? I did replaced the line (earlier) going accross to the other wheel as it was broken off at the connector, and it look like it was broken for a long time. I am thinking there might be all kind of rust and garbage inside. I did managed to get oil accross with the new brake line but maybe the left side's cylinder is gone as the line was broken right where the line comes in.
Any advise and suggestion on how to procede is greatly appreciated.
Ray
Yep, sounds like the wheel cylinder is a gonner. Yes, one brake shoes get fluid on them, you should replace them. I would rebuild the whole thing down to the backing plate while you got it apart.
Ray, are you in salt water or fresh? IF Salt, and you have drum brakes, I'd ask you to consider going to a disc brake setup. If you don't want to do that, you can buy complete drum brake assemblies (backing plate with cylinder, shoes, all hardware) quite inexpensively. Just be sure to match up drum diameter and shoe width, and replace right with right, left with left.
If you go disc, the lines from axles to brakes need to be changed from metal to rubber and the actuator modified for disc, or replaced with one meant for disc.
Thank you for the replies. I will be putting it in fresh water mostly and maybe once a year in salt water. I might just keep the drums setup, (limited time/budget). I will be looking at getting the whole kit for marine applications.
Thanks again,
Ray
I am just wondering if anyone has done what I am thinking of doing. I don't know if it's a good idea and it seems like none of the shops around here know either. I am replacing my hydraulic brakes assemblies with new ones but I am also thinking about installing electric brakes on the other axle, being that I already have the controller on my truck. My question, is there something wrong about having both without electric over hydraulic setup? Do I still need a break away kit when I already the hydraulic's?
I think that is a recipe for disaster. Put on an electric over hydraulic and be through with it.
My guess is that a surge hydraulic system plus an electric system on the same trailer would get into a duel, applying and releasing, till things got ugly.
This is why is good to hear other people views. You made me think of a few things I missed on my planning. thanks again.
Ray
I had this same problem last fall.
Cylinder started leaking.
The cylinder is available from a specialty supply house only, and a real pain to replace.
As said above if you can afford it change to disks.
There are several great trailer web sites with a wealth of info.
It's not real easy depending on your mechanical experience, but well worth the effort.
Abouttime
Ray,
In my opinion, drum brakes are junk. I never knew if they were working or not! Once I switched over to electric discs, I could engage the manual override on the dash and I KNEW they were working. I wouldn't go back to drum brakes if someone gave them to me for free. After I saw someone do the changeover to discs on one axle on my trailer, I did the second. No sweat.
Good luck, Peter
Originally posted by Cobalt 25
Ray,
In my opinion, drum brakes are junk. I never knew if they were working or not! .........
If you want to know if your brakes are working, regardless of type, buy an infared non contact thermometer. Sears, Harbor Freight, etc.
Measure the temperature of the rotors or drums before you start. They will be about the same temperature as the surrounding air (ambient temperature). After driving and using the brakes, pull over in a safe location and take another measurement. The rotors or drums should be much warmer than ambient temperature. This indicates that they are working (or possibly dragging). Brakes work by converting motion to heat through friction.
Note: If the rotor or drum on one side of an axle has a significantly different temperature than the rotor or drum on the other side of the same axle, you have a problem that you should address ASAP.
