Hydraulic Hatch Piston Failure
Sandy K.
The hatch that provides access to my engine room has a hydraulic piston that keeps the lid up, while I go below. This past weekend I noticed that the piston does not keep the hatch up. My buddy said that the heat from the engine room has caused it to fail.
Does this make sense and is it something that can be repaired or should I just replace it? If I replace it, what specs do I need to know so that I buy the right part?
TIA,
The struts are not repairable. Get the part number off of the bad ones to find a replacement. Easy 5 minute repair just make sure that the hatch is securely tied up or some one is holding it when you pop the old one off.
You can go to auto part stores and maybe get the same kind of thing, I have those on my SUV. You said it holds it up, inplies it does not raise it. You could also, if you have to raise the hatch, drill a hole in the up position in the piston shaft and put a pin in it, when up, that is what I would do.
Turns out that it was a 15" gas charged lift - fortunately it's a Taylor Made product. It was a very simple fix.
