We have a 2002 Carver 350 Mariner with the SeaStar hydraulic steering system and loose about 1/2 ounce of fluid over a 6-7 week period. Cannot see any leakage around the helm pump connections or at the cylinder connections. Seems to leak that small amount and then stops, fortunately never loose steering.
Where could the leak be located that it does not drain the entire system ? This is a flybridge helm and the wheel is the highest point of the steering system.
Does anyone know how the hydraulic lines are run from the helm down to the cylinder ?
Should I consider running new lines ? Is it even possible ?
thanks for any suggestions
Rich
Rich
