Hydraulic Swim Platform Question
hock90
Has anyone had any experience installing the hydraulic jacks into a hydraulic platform themselves?
I have a Formula 40PC that is set up for a Hydraulic Platform. Apparently this was an option in 2001 that the original owner did not opt for. However, I am told that it can be added with the hydraulic jacks and some other minor additions. I am starting to think that it would be a fun addition to the boat, but maybe way more cash and work than I want to put into it.
If you have some knowledge in this area, let me know your thoughts. Thanks....
I looked into, and realized I can buy a new car for the same money. Can't justify the expence.
Why would you want one of these? What does it do, actually? Does it fold up out of the way, or just raise up and down?
Bob, most folks use it to store/launch a PWC.
So, it goes up and down? That's kinda cool, but yeah, I bet cost prohibitive.
a lift on your swim platform is the cady of lifts for a dinghy. if you aren't going to carry a dinghy there its probably not worth the nearly 20K to do it. a less expensive alternative is a davit you can do an electric one of those for about 7k. there are less expensive roller type systems if your dinghy is an inflatable or ultra light RIB with a small outboard. based on the size of your boat, it may not be wise to put the lift there as the beam of your boat is not really sufficient to carry a larger and heavier RIB that would require it. a smaller lighter tender won't need the lift and the weight that far aft does make a big difference on boat performance. the lift mechanism alone will add about 500# to the back of the boat and a traditional RIB or jetski will add at least another 700# to that. you may want to just put it on the list of things to look for on the next boat.
Formula customer service would be the best one to answer your questions correctly. their number is 1-800-736-7685.
i believe the platform lifting equipment is manufactured by lewmar. they used to use tnt but changed some time ago. Formula would have the info. Good luck.
they are used to store a tender or PWC and launch it by lowering the platform in the water. easier than using a crane or tilting devices. They are also nice to hang around on when the tender is off, you can sit in a few inches off water. great for pets too...
on the down side, you still have the tender in your way whenever you dont' launch it, although that's always the case when the dink is stored on a platform.
but the killer is the price, as others have said, they cost aroudn $20k depending on the size...
Thanks for the info on Formula Gary. I have found they are quite helpful, but I am curious also if anyone has tried to install these themselves.
Let me make it clear that the 40PC has a seperated platform that is set up to be hydraulic. In talking to a couple of people who now the boat fairly well, all that needs to be installed is the hydraulics and that is supposedly it. Apparently, Formula offered this as an option on the 2001 40PC and only installed the hydraulics in the boats that the option was chosen. It was supposedly pinned and the hydraulics obviously not installed in boats that the option was not chosen on.
So I guess the question is for someone who may have had some sort of similiar experience with adding this option. Has anyone simply had to replace the hydraulics in their existing platform? That may give me a spot to start.
I agree Formula is the easiest route to the info and ultimately who I would have to talk to get this completed. I just wanted to get everyone's thoughts.
Pascal - And yes, it is unfortunate, but this is mostly for the pets and to play with while on the water. It is sad what we do to bring along the pets and for bragging rights........
Our 48 was designed to have a lift. I would not own one without it. We rarely carry our digny, but always carry our wave runner. The lift makes it very easy to carry even the way (160 miles) down to key west.
On day trips, we take the wave runner up to North Captiva for a day of skiing, tubing, or wake boarding.
On our old boat, we towed it. A PITA.
