I need basic info on electronic tachs
jdshep
I have 2005 Meridian 411 with Cummin's 370's. On my boat I have a Glendenning (i think electronic) engine synchronizer. here is the question? I have upper and lower helms, I get the same reading (close to same) on three tachs, but the starboard bridge tach is near 200 rpm higher, however based on boating tests and my GPS speed I think that tach might be closest to correct rpm(just over 3000 rpm just over 30mph). I asked this question before and did get some help, but i did not do anything so i forgot what i was told. The Meridian rep told me about different taps on the back of the tach, but again i have forgotten the details. I think I need to get a true reading on the RPM and i understand this can be done with a portable tach that reads flywheel rev's. I could buy that tool o Ebay if i was sure that would work (comments). On the tachs, (brand don't remember others might) anyone know if taps(?) are a source for small changes?
I am not Trolling (new term i just learned) I am looking for help (general help, friendly help) if i can get it.
Thanks in advance
John d
Jd, first thing you need is to get your memory back......maybe some vitamins or one of those handheld memory games???? When youfigure out what works on the memory thingy, let me know. Mine keeps getting worse every day LOL
hand held laser tachs are available at harbor freight for $40.
I am sure it will be easier to fix the tach's then it will be to fix my memory.
John d
Four ways that dash tachometers recieve information: 1. mechanical drive off cam shaft to the mechanical cable directly to a tach (not common in modern boats) 2. electronic sensor off the mechanical drive on the cam shaft, with a cable to the electronic tach. 3. Alternator output wiring to an electronic tach. 4. Computer output via protocol (may be NMEA 2000) to a screen or electronic tach. Most likely yours is an Alternator output. Although the boat is new, the Cummins 370 is an older design engine--but it could have a computer output....
The photo tach as mentioned above uses reflective tape on the flywheel to measure the RPM. Even a cheap one will work here--since you want relitative and repeatable RPM--not absolute (to .1 RPM) accuracy.
You can usually adjust the tach with a turn of the rayostat with a screwdriver into a small hole in the back of the tach. Usually the taps are for gross adjustments as related by different transmitters or alternators which have different numbers of poles.
Good luck
Best information I have heard, with this i think I will tackle the problem. Anything special i should know about screw adjustment? Like do not use metal screw driver?
John d
I have the Glendinning synchroniser in my 3988 Bayliner which is cable driven from the tach takeoff at the front of the engine.
The dashboard tachs are driven from a magnetic pickup on the flywheel back by the transmission on the port side which is set for 156 teeth on the flywheel,,, yours will be too.
I suspect that in reality 3 tachs are right and one is out of adjustment. Pull the tachs and check that they are set right. Move the adjustment and put it back although it is a new boat there may be corroded contacts there.
Verifying your WOT RPM is a good thing as typically manufacturers prop for good performance claims not for real life loading of the boat.
Once you get all this data you may find that an inch or so less pitch will be beneficial to engine longevity.
Today I bought the laser tach on ebay, next I have to learn more about the adjustment of my tachs.
John d
How much did you pay?
I just went through this...exactly as Bob described. I had to change altenators in both engine and they had a different number of pole. My tach's have a plastic screwdriver adjustment...I just "winged" it though and would like a good calibration.
