Ice in Bilge
Brian
Was out at the boat the other day. I saw some ice forming in the blige so I put some AF in. Will the AF melt the ice that had formed already. It was just a small amount of ice.
That is a really good question. I dump a small amount of the PINK stuff in all of my bilge compartments as I winterize the whole boat. Midship thru hull fittings, bilge pumps or transducers may trap water in pockets or low lying areas. Better to be safe than sorry.
Any chance of putting a small heater down in the bilge? Freezing water can damage hoses and fitting and can cause catistrafic failures. Even months after the freeze.
Antifreeze will keep the water from freezing, but it won't melt ice.
The pink stuff will, as will windshield washer fluid. Works great on frozen scuttles.
Don't spill your cocktail into the bilge, that keeps the ice out. Oh yea, yoooze-skies are way up north past Baton Rouge. When you live south of Highway 90 the only worry you have about ice is keeping enough onboard to keep the shrimp/fish/oysters/crabs/beer cold.
Do not, I repeat, do not put a heater in the bilge inless it's either rated for such use (ignition protected) by the manufacturer or it's a diesel powered boat.
Heaters and gasoline fumes are an explosive combination.
I believe it will melt the ice but even if it doesn't melt it right away, once the temperature rises above freezing and the ice melts, the antifreeze will keep it from freezing again.
I wouldn't worry about the bilge, I'd worry about the fittings, hoses, pumps, and engine.
