Ice in boat
rain water ? how does so much rain water get in to the engine room of a sportfish in the first place ??
something isn't right here...
Looks like some thru hulls are leaking, or maybe some rudder packing glands. At any rate it does not look good to me. Also looks like the bilge might have just been sprayed down at end of the season to cover the water lines from season past, I noticed allot of white paint on the hoses .
Well, at least the engine room could double as a deep freeze/root cellar for a while until the engines ruin the fun.
I think I'd be looking for a different boat unless it was thawed out, fully inspected, and sea trialed, all that being done after my very low offer was accepted.
Looks fishy. Even if that was rain water, why didn't the bilge bumps handle it. I'd also be concerned about what damage may have occurred due to the freezing.
It's not so bad that they painted the bilge, but you have to wonder if it was prepped properly. My guess is that all that nice paint is going to flake off. One of my pet peeves is why painters can't remove (or at least even mask off in this case) trim, hose clamps, wiring harnesses, etc. The extra hour or two of work makes for a 500% better job.
Not good !! I think the only consideration I would give would be to consider running away. However if yur customer is really interested I would make any offer conditional on the boat being thawed out, and complete hull and mechanical survey, followed by a through sea trial.
Didn't I see these pics. elsewhere?
Must be real cold, note the white frost everywhere! :-)
On a smaller scale, my boat has a tunnel pocket, so the drain plugs are up above it which leaves a puddle of water around my shaft/stuffing box. I messed with the jackstands last year to try and drain it better, then the marina wondered why they couldn't get the lift under there in the spring. oops This year I hand pumped that area and put anti-freeze there after the boat was covered.
On a larger scale, my old Connie's bilge looked like that 3 or 4 years ago when I rowed a fresh battery out to the mooring, boat was on the front page a few days later. Big oops!
Ice is never a good thing, that's why they invented boat covers. That and what looks like "Krylon rebuilds" would have me shopping elsewhere.....
As it was explained in a thread about bubblers, when water freezes it expands ... and exerts a tremendous amount of force. Who knows what has been damaged by the ice. I think someone summed it up best when they said run.
In this case, I don't think freezing water in a bilge would create damage from expansion. It would simply expand upward and raise the water line. It would be like freezing water in an ice tray, no real stress anywhere. I'd be more concerned with the effect of deep freezing all the hardware and stuff (wires, hoses, fitting, etc) that was underwater. I agree, the guy with the white spray can should be flogged or keelhauled. Poor attempt to cover up a poorly maintained bilge.
I had a ocean ss 1999 it does have a drain about mid ship. Yes it could be rain water If left un coverd for the winter it could very well have that much water in it . Ben there done that. Only in a much warmer climate
Is this in water or out...I guess they dont have bilge pumps either if in water.
Agreed, I was referring to the all the components in the bilge that filled with water and then froze.
waterdog, how do you get rainwater inside a sportfish ER which is under the saloon? i can understand a little bit getting in if the cockpit hatch gutters are too shallow but this is a lot of water and it's in the ER... means the boat woudl have had to be blocked bow down for water to move forward...
