ICW Nav Aids
jrpar
Who maintains the aids to navigation on the ICW (FL)? I took a run last night thru part of the ICW and there must have been 4 or 5 marks that were not functioning.
Would it suffice to call to the Mayport CG duty officer or is there a specific number to call...?
USCG, call the station and give the location (channel) and marker numbers. Read your Local Notice to Mariners, they may be listed as discrepancies.
did you check the Local Notices to Mariners? chances are they are listed there unless they failed recently.
check that, if not listed, report them to the USCG.
LNM doesn't have them...That's a first for me in this area..Hence the question...
Thanks for the replies..
The Gulf Coast ICW has lost a few mile markers after Hurricane Rita, but all the
lights and day markers are working. I guess the mile markers are not as important
as the other nav aids.
It is good that you are reporting these. Unfortunately, there are many crab pots just on the edge of the ICW channel and if you drift off the channel even a little at night, you will have a problem. This is especially true between New Syrmna and Melbourne.
That is one reason why I don't cruise or fish too often in the ICW at night. Its too stressful.
well, if you drift off the ICW you will usually have more to worry about than a crab pot :)
between New Smyrna and Melbourne, I don't recall too many pots near the channel compare to some other sections... actually, in some cases i find very useful since they are often placed on the edge of the shallow water!
I've run a few hundred mils at night in the ICW last month, no issues with pots.
I've found the ICW to be much more forgiving (pot/trap-wise) than many of the areas I frequented up north. Approaching Stonington, CT had to be one of the worst sections of carpet bombed lobster pots I've ever been thru. 500yds of channel packed with enough buoys to float a small battlewagon.
Pascal... Drawing on your recent experience...How well maintained did you find the aids during your night runs? I like to run at night, but could have found some skinny water had I not had local knowledge to backup what I was seeing (re: visible marks).
i dont' find it significantly more difficult at night... frankly, day or night you can't see what's under the water so it doens't make a big difference.
the sections I ran at night were Jupiter to Port St Lucie, St augustine to Fernandina, Port Royal sound inlet to Dawoo River (just south of Charleston), Wrightsville Beach to Beaufort NC). NAv aids are easy to find with a spotlight which you can use as needed since there is almost no traffic at night.
I did the basic navigation relying mostly on the nav aids and then used two completly independent GPS receivers/plotters to find the best water (one built Furuno and my laptop running a USB GPS and seaclear). For that, I usually start by staying near the magenta line but also relying on the sounder and common sense near turns or locations where the line may not offer the best water.
the bottom rarely just jump at you in the ICW unless you are way off course, when going slow you can "see" it coming, usually. when i see that depths are slowly coming up, i alter course a little and see what happens. if it goes back down, then that's where the better water is... if it keeps coming up, then i try the other way.
Your approach mirrors my own.. Depth finder is one of the best (and most neglected) tools.
I was in "teaching mode" with my son using only the paper charts and old Mark 1/Mod 0 eyeballs. I asked about your experience outside of the Daytona->St. Augustine section, as it seemed like a larger-than-expected number of lights were out. Granted, daymarks reflect quite well when exposed to a quick flash of the spotlight, but when the charts call for a "FL R 4s..." and you don't have any lights showing on consecutive marks...??? I hope this is isolated and not the condition of the whole waterway..
