I just remembered...last Monday, when I arrived at my boat, the main breaker, on the dock was tripped.
We are using our aft cabin heater to warm the boat. We left it on 60 degrees, which should be plenty to keep the boat above freezing. That and the temp of the river water.
BUT if we loose AC power again, I don't know if our heater will come back on. A golden rod
will. That helps a little.
Also, I talked to WB about 5pm, they said no problems so far, might be a couple of minor pipe breaks, but they are leaving the water running.
My water is turned off. I probably should have unscrewed the hose, laid it on the dock and let it run at a slow rate. In fact, I may just get in the car and drive down there tonight to do that.
Everyone else ok?
Everyone else ok?
