In Florida....
Jim G
I am told that even though my macerator helm switch requires a key to turn the unit "on", I am still required to have the thru hull wired shut. Is this correct? Thanks
i am told the same thing.
the question is how many times is that really checked?
"I am told"
by who ?
the USCG rules don't specify what specific method needs to be used. Even a padlock on the head door is enough. if there are any specific new rules in florida, what are they ?
florida specific rules for MSDs are one sentence long : "Vessels operating in Florida waters must comply with the U.S.C.G. requirements relating to marine sanitation devices, where applicable."
(http://myfwc.com/boating/safety/law_summary.htm)
USCG rules : "Some acceptable methods are: padlocking overboard discharge valves in the closed position, using non releasable wire tie to hold overboard discharge valves in the closed position, closing overboard discharge valves and removing the handle, locking the door, with padlock or keylock, to the space enclosing the toilets"
(http://uscgboating.org/safety/fedreqs/equ_sanitation.htm)
by who.... a trusted friend with a masters license and more hours behind the helm of a boat then i have in a car.....and now by pascal via the link provided above.
i should have elaborated a bit before (sorry phone rang). my friends comments are there needs to be a means to prevent accidental discharge. wiring the thru hull shut would act as one of those means. as pascal noted there are others that should work as well.
"I am told"...by a guy in a boat who had a bad experience w/ a water cop...it's his interpretation of the "law" that no matter what else, one must have the thru hull rigged to prevent "accidental opening". Too me, it sounds ludicrous but I have never boated in FL; but, maybe its run by the same people who run elections :-). I am not in Florida yet (but my boat is) and am just trying to figure out whether this is a big deal or not.
I use a plastic wire tie with the Y valve in the position for the waste to go into the holding tank. The sea cock thru hull comming straight from the head is also closed. I have a keyed switch that turns on the pump to empty the holding tank pass the 3 mile limit. Keep key in drawer. I have never used it but I can if needed,I just suck out the holding tank at pump out station.
I have a closed macerator seacock valve. It can be opened by climbing over the engines to the very aft of the engine compartment.
Then I would need to go into the cabin and push the overboard system switch to on. Then I would need to push the actual macerator rocker switch.
Having a pad lock on the seacock valve would just add a step if I wanted to discharge.
So my question is with all the steps that I would need to do, is that enough for the USCG ?
Maybe Mike [November Charlie] can give his input here......Mike?
The discharge must be under the captains control. Put the key in your pocket and ask "your friend" to try to operate the mascerator.
You are in compliance with a keyed lock disabling the system.
radio, if you dont' have a key switch, you must secure the seacock with a padlock, a tie wrap or by removing the handle.
if a watercop is giving anyone a hassle over this, he doens't know what he's doing. Having a printout of the regs maybe useful.
btw, my prevkious boat (98 vintage) came with a pair of hold to run rockers. you'd have to keep TWO fingers on both switches to run the macerator which had above WL discharge and no seacock. I have to assume that the double hold to run rockers were in compliance with USCG rules.
We have been boarded several times in Florida, and in each case just looking at the "Y" valve in the holding tank position was satisfactory. It might depend on what water cop you got, and where you were. For example there are some "no discharge" areas in Florida--and in those places I can see the lock being enforced. (Destin, and in the Keys Marine Sanctuary)
I have a key switch to operate the Macerator in the head, the key is on the wall out of the switch away from the head in the salon, then I need to turn on the breaker for the macerater and change the Y valve position and open the thru-hull (not in that order). I am not going to run with the thru-hull open because it backfills the waste tank. I feel I am in compliance even though I don't have the thru-hull locked or the handle removed. The discharge circuit is electronically locked by the key switch and the key is only in the switch when I am legally discharging even then the circuit breaker must be on.
Regards Bill
who installed that holding tank and macerator ! running with the seacock open shoulnd't result in teh holding tank back filling... you're missing a syphon break, not a safe setup.
I will call the marina tomorrow Pascal they did the installation. They mentioned after the season they needed to do additional work on the waste plumbing.
Thank you. Bill
geez.... oh, we installed, you paid the bill, but we might have to adjust things a little in a few month assuming your boat hasn't sunk in the mean time.
nice :-)
(sorry... i'm suffering a sarcasm attack)
I'd like to see the water cop climb over hot engines to check my discharge valve.
But first, he'd better have a search warrant to go down into the engine compartment, as the Constitution protects us from unreasonable search.......
I removed the handle on mine when we were on Lake Norman. Obviously an inland lake you could not discharge anywhere, I put the handle back on periodically and dumped overboard (just kidding) I did work the valve periodically to make sure it didn't freeze up. The point is to prevent an accidental discharge.
The t handle on my valve was tie wrapped to the valve when I got my boat. I took it off once to empty head in an emergency, and just put it back on the valve the way it was. Its no big deal to place the T back on if you need it, this way the water cop has nothing to say.
I was boarded on the Appomattox by the USCG Aux. My valve was closed and not locked. They cleared me saying if you can get to that over hot iron, good on you, however, please put a zip tie on it. If you want a non issue, get the neon ones from Home Depot as they are easy to see. Small inconvenience at most to put it on. I did not have a "Y" valve on the Regal. I have not checked how the Sea Ray is set up.
