- Jul 27, 2001
- 5508
- 1,264
Has anyone used the nylon bushings, on inboard props? They are used in the event the props are sized wrong for the shafts. I have three blades on my Viking, 23x23, the bore is 1.5”. They are a bit dinged up, but before getting them tuned, I was looking into buying some four blades. New are too expensive. when looking for used I saw a nice clean set, correct diam and pitch, but the bore is 1.75”.
I always assumed that using a bore reducer would be a bad idea, leading to vibrations, or other performance issues as a result of the extra strain around the key. But talking to my prop guy yesterday, he says that as long as you use the right key, and install correctly, they work fine and no issues. Any opinions? Researching a bit more, I see that bronze bushings are also an option - but of course three times the price.
propshopinc.com
Anchor Bushings Bronze Propeller Bushing - 1-3/4" Bore to 1-1/2" Shaft (BB13)
Anchor Bushings 1-3/4'' prop bore to 1-1/2'' shaft size bore reducing bushings available in Bronze to reduce your propeller bore to fit onto a 1-1/2 inch shaft. Fits 1-3/4'' prop bores. Part # BB13.
