Inflatable storage on aft platform
Reddogg
While looking for new and better ways to store my hard-bottom inflatable
I've come across a product from Hurley Marine. This product mounts on the
stern platform, extends aft under the inflatable, allows for horizontal storage of the inflatable with
outboard installed, and launches by tipping the dingy back into water. It
looks easy to use and very affordable ($800). I'm wondering if anyone has
experience with this product.
I looked at it before I went with the Weaver Snap Davits. I didn't like the way the Hurley system stuck out past the end of the swim platform. I visit a lot of places where I have to dock stern in, with no fingers on the side. The hurley system looks like it would give me a lot of difficulty that way.
$800 seems far too much money for the product that is only a few feet of stainless tube and fittings. For that money you could install rpoper davits that would lift the dinghy clear of the water.
Reddog,
I owned one. It turned out that I couldn't use it due to the height of my swim platform to the water. That height on my boat is a full 28". It proved way too steep a drop for the dink going into the water. It would take water over the side. Further, it was useless trying to haul the dink back on again, due to the height. If your swim platform is a reasonable distance off of the water, it would work fine. The other thing I didn't particularly care for was the trying to find ways to tie the dink onto the davit system once aboard. You have to secure the boat onto the platform by some other means than the davit. Lastly, I hated the way the dink took up the whole swim platform.
Frankly, I think the system is WAY over-priced for what you get. But that holds true for most dinghy mounting systems.
Otherwise it's great.
I'll throw in my 2 cents. I was looking for a way to store my dink on the back of my 28ft express. I looked at the Weaver snap davits but didn't like the price which is cheaper than the other thing you're talking about. I finally found C-Lifts from Plastic Innovations. For $90 bucks they make launching, retrieving and stowing the dingy on the back of the boat pretty easy. The website is a little lite on details so I was skeptical but after having used it several times, it works as promised. You can't beat the cost and no need to glue anything onto my brand new dingy. Not sure if it will work for you but I thought I would mention it.
I bought and installed the Hurley system in the last week. This was to replace a lift system to store the dinghy on the foredeck which is a 20 minute process (on and off) every trip out. I have an Avon 310 RIB with an 8Hp 4 stroke (almost 200 lbs).
Good news: 1)The top of my platform is only about 8" off the water. 2)After some serious grunting and pulling, I'm underway in less than 5 minutes.
The bad news: 1)The dink is very heavy in the first place, so I'm worried about trying to pull it on in rough water. It was hard enough in my slip. 2)There is no way this thing is worth over $800 retail. I think it would be fair to price it around $300 to $400.
I can say, however, that this system matches exactly what I needed and I personally don't regret the expense. Just seems too high for the average buyer. If this thing sold for $300 to $400, I would predict an enormous increase in sales.
There is also the OMS davit system JS50--which uses rollers and a which to bring the inflatable (like an RIB) over the platform from the side. This one is really pricey--at about $4K!
Also one has to have a wide swim platform--36" is probably the minimum for most of these tilt davits, without SS bracket extensions.
Reddog - There's a thread somewhere in BE history on this... from last year, if I recall... Bob H. and I both posted to it (I recall his high dive platform disguised as a swim platform) ;-)
I have the Hurley setup, and I LOVE it. I bought mine from him on eBay (cancelled order), and bought it for around $400. The reason I went with it is that I have an express cruiser, and didn't want the dink standing up like a billboard on the swim platform when I was under way. I bought the extended rails, so I left walking room on the platform, which makes moving around much easier. Lifting and deploying is a breeze. Bob is right in that you have to come up with a SECURE method of attaching the dink to your boat. I tried to get away with the large suction cup & straps used for tubes and such, and wound up losing my dink in the middle of the Chesapeake Bay. Fortunately, a great blow-boater picked her up and responded to our pleas for help. Install the tuck-away cleats or rings, and use the straps he recommends.
It is also true that the Hurley leaves parts that extend behind the swim platform. It's never caused us any grief, though.
Well my dink isn't a rigid hull, but it fits on the back of my Cruisers 370 just fit, sitting on it's own bottom with no davits. It's a 9' Mercury with a 4hp outboard, easy to lift up and out, and easy to launch. My only concern is that the dink is blocking my transom name and hailing port. Isn't it required to have the name and port clearly visible at all times when you're CG Documented?
Yes. I've seen dinks that had the documented name & port painted on the bottom of the dink to resolve your type of problem.
The dink sits on it's bottom on the platform. Here's a picture.....
I thought about putting something temporary on the side of the dinghy or maybe on the back of the swim platform.....I just think I am going to get stopped by law enforcement if I don't have the name and port showing unobstructed.
Off topic I know, but the hill of Radioguys stb side looks like Puget Sound country. Makes me homesick....
Question on the C-Lift system.
First, can the C portions be removed when you're on the hook and the kids are using the swim platform to....swim?
Second, I assume they are drilled in, is that correct?
Third, do you keep the dink on the c-lift while underway?
The C-lift with a rigid 3/4" SS pipe to keep the dink away from the transom would work perfect for me.
Chris, I have the plastic C lift system. You have to drill holes in the swim platform for the mounts - the "C" ring then fits into the mount and can be removed - leaving just the small mount.
Yes, you can operate the boat with the dink on the mount, I do it whenever we take a long trip.
If you want to check it out, stop by and I'll show you.
I think it's the best system for the price.
Thanks Mike, darn, now I'll have to stop by and drink some of your cold beer...still have that bottomless cooler?
My swim platform is I'd guess 12" above the water...do you think that would be a problem? The dink actually fits UNDER the platform so I'm concerned I won't have the leverage needed for the pivot.
Mike,
Forgive my intrusion here, but I just installed the C-Lift and I was wondering if you could answer a question for me? I'm not sure how to configure the spreader and the lines - the instructions are sparse and there are no good pictures for guidance. Can you tell me how you have yours? Also, do you pull your dink right up against the stern or do you use some type of 'pipe' to keep the platform somewhat accessible?
Thanks for any help!
I have also found the C-lift method works very good for me. I used bimini hardware to make two stand-off attachments to hold it in place at the edge of the swim platform. I used aluminum rails for ease of working with them and cost and they have held up fine. I put one attachment bracket on the wood transom with the other end of the rail attached to the stern of the boat. All attachments are the style that use pins that can easily be pulled to remove the rail. On the bow end of the dinghy I attach the rail using a longer pin that I push through one of the safety line holders on the dinghy and use a ss safety pin to secure it. You need to find a marine store with a good supply of the various pins and attachment hardware and just figure out a method that will work for your situation.
Chris, you'll have to lift one tube of the dink a bit to fit it into the ring, then you should be able to pull it up.
I keep mine flush against the transom.
manticore, I have the lines criss-crossing at about the center of the dink, then I tie them to cleats on the transom. I also use the painter tied and a line from the dinks transom tied to cleats to keep the dink taught against the transom.
Originally posted by manticore999
Mike,
I agree, the instructions are sparse. I attached the ends of each white line to the short ends of each "C" by sticking the end thru the hole and tying a half hitch so it wouldn't come back thru. Then I weaved the end of each line thru the provided "seperator", that little white square with the holes by weaving in one corner and out the other. With the Dink hoisted up on my swim platform I adjusted the seperator so that it was in the center of the bottom of the dink making the lines criss-cross the bottom like an "X".
When under way I have the dink pulled tightly against the transome with each lazy end of the line secured to an aft cleat. The thing doesn't budge. When I am leaving or pulling into the slip and need access to the swim platform, my wife unties the lines and tilts the dink back so it's tipped slightly backwards off the platform. She then ties the line off on the cleat opposite our transome door. This way she has access to the swim platform for docking.
