Inspecting impossibly tight spots
Radioactive
Well-known member
Though I never had to use it ( thank goodness! ), I bought a 9v battery powered wireless color camera ( used on model trains, for a view from the engineers perspective ) and receiver. Cost less than $100.
Attached to a stick or other device, the camera can be placed in areas even your kids wouldn't dare, such as behind bulkheads, or in those "trapped" areas of the bilge you so often find in new boats. And you can view the area on a small portable TV. Sometimes this would be even better than an inspection mirror.
( Anyone who has done this, let us know! )
Besides watching divers, fish and checking out sea bottom irregularites noticed on the F/F, I've used my B-I-L's b&w U/W tv cam ( Atlantis Camera) on a cable a number of times to find things such as a corroded/leaking tiny section of pressurized crank-oil pipe way down low on a big marine diesel, finding small parts dropped into otherwise inaccessible bilge areas , & hanging it over the side to inspect major running gear fouling by a shellfish polyscrim bag at night. Definitely reaches spots mirrors will not and can see things in real time on the included remote TV monitor, but color would really help define separate objects. These can be such a big help when there is no other more reasonable way to get into those spots.
Radio - Can you direct me to your very slick-sounding cam?
I got it at Micro Mark ( you have a PM ).
I would guess that the same item or equivalent is available elsewhere for less... It was that they had it when I was looking. Nevertheless, they had it as a nice package ( battery included! )
It really is small. The 9V is much larger than the camera.
Thanks, Bill, rec'd the PM. I did find a bunch of the little 9v model rr cams online last night but yours looks like the nicest setup. Even though the cam is 9v battery powered , you still have to plug the tranmitter & receiver into 120VAC, and hook the receiver to a monitor tv or VCR, right?
The b&w Atlantis system w/100' cable I use onboard is completely self-powered from it's long-lasting rechargeable battery in the Pelican Case also holding the 12v monitor run off the same battery, but it's a lot more expensive (at least $600 a long time ago) and color upgrade is a lot more.FWIW, If I was just buying the Atlantis now, I think I would pretty definitely go for the color cam that can be remotely rotated 360* from the surface. In any kind of drift or current, it's difficult to see the sea bottom in other than one direction with the cam I have. .
" you still have to plug the tranmitter & receiver into 120VAC, and hook the receiver to a monitor tv or VCR, right? "
That is how it looks, but the receiver is powered by a 12v DC "wall wart". This means you can use any 12v DC source.
