Inspecting prop from dock
san
I may have a fouled prop on my 38' single inboard. Has anyone come up with an idea to inspect a prop from the dock perhaps using a mirror or fiberoptic?
I'm sure there has to be a way to do that but it might be less expensive to hire a diver to check it out. If there is a problem he could probably fix it.
go for a swim and clear it yourself...
I've done that myself with a big knife. Keep in mind that water under some marinas is extremely dangerous... current, snags, cold, etc.
http://www.highlights.com/jump.jsp?itemID=1848&itemType=PRODUCT&iMainCat=107&iSubCat=119&iProductID=1848 Seriously, some one did make a gizmo like that. Can't seem to find it right now.
That's great. Certainly worth having at that price. Last summer, I dropped a pair of sunglasses off my swim platform at my dock. I went down with a SCUBA tank and goggles but I couldn't see a foot in front of my face. The water was so dark and murkey. I tried to hover face down just over the bottom but I still couldn't see anything. Might as well have had my eyes closed. Even with the LED's, I don't think I would be able to see anything.
I have the camera in Currentsea's post. I bought it on ebay about 4 years ago. It works great. You have to buy another device/package if you want to use it with your laptop. I have the PCTV from pinnacle systems.
Harbor freight has an underwater camera.
You can also make a view box. It's just a water proof box/tube with a glass bottom.
Add a mirror at 45* so you can see under the boat.
Same principle as a glass bottom boat.
I'd be hesitant to enter the water at the dock. Stray current could make a fouled prop a moot point if you're not around to enjoy your boat.
straight current is almost never an issue in salt water... in fresh water, you're right, it can be dangerous to get in the water near a dock/marina, but if he is in salt water, it's fine...
Don't need to sound stupid, but why is stray current not a issue in salt but is in fresh?
I'm curious about that, too. Does that go along with electrolysis?
In salt water, it depends on where the elect. is comming from.
It takes the path of least resistance.
If it comes from the dock/boat next to you, it should go straight to ground.
If it is coming from your boat or dock/slip, you would have to touch the
wire or conductor for it to go thru you.
The salt water is a conductor. It will go to ground as soon as it hits the salt water.
In fresh water, it is looking for a path to ground, which could be you touching a grounded object.
You still need to be careful about stray currents that act like concentric circles from various boats or voltage producing sources near you and possibly your boat. One way to possibly minimize this might be to disconnect your power lines before using a metal knife in your bare hand while you are clearing a grounded prop shaft. Also as an additional precaution use only one hand to do the cutting. In salt water these stray currents will travel further than fresh water. I would just use extreme caution. Why not just have the boat lifted then check the props and have the marina drop the boat back in? It wouldn't even have to come of the lift. Our marina has a policy no swimming if you want to hire a diver they must see the divers insurance. Also at the risk of sounding stupid make sure you haven't run your generator for at least 15 minutes because CO loves to accumulate under swim platforms.
The saltwater is the conductor to ground.
It should go straight to ground, unless your body goes between the source and ground.
If you touch the boat and the dock, you may be the path of least resistance.
Fresh water has a lot more resistance, therefore, you would be the short path to ground.
Thanks very much for all your help, I took Pascals advice went out and anchored in the harbour. Jumped in with snorkel and wetsuit but visibility was next to zero due to recent bad weather. Going out of the marina at idle it lost a knot due to whatever was dragging so after the swim I did a couple of figure 8s at about 10 knots and it freed itself from what I now believe was draped around the rudder post so all sorted.
I jump in fairly regularly to inspect running gear and zincs, etc. & lightly scrub the hull bottom, but also several times have used an Atlantis U/W vid cam on the end of an extendable boat hook or taped to an 8' or so curved length of well-pump tubing ( which makes it easier to maneuver) to inspect for suspected line or net in props. The sensitive vid cam is surprisingly effective at night with no add'l lighting needed and can show me if a problem is more than I should jump in and attempt to clear under present circumstances.
It comes with a nice waterproof Pelikan case including a B&W tv monitor. It's also very handy for inspecting the bottom of the inboard engines or other very difficult-access spots...and of course for checking fish structure up to almost 100' down.
I jump in to clean the crud line off the boat several times a year also. In salt water.
Never at the dock though. Only when at anchor.
