Inspection plate aft fresh water tank
ken emigh
1996 Carver 380
The aft water tank is leaking and it appears it is at the inspection plate cover. Because of its location I used an inspection mirror and did not see a crack around or near the inspection plate. The plate cover appears to be a screw type however it won't turn at least not by hand. It looks to be sealed? The cover has vertical nubs on the edge, is there a spanner wrench for these plates? Or can I just use more sealant around the plate? What type of sealant would work,5200?
Thanks in advance.
There is an o-ring around that "nubbed" cap. I've always been able to open them with large channel locks.
Will give that a try in spring as boat has been stored for winter.
