Originally posted by In the know
Assuming your core is wood.
Follow the drill/fill/drill method. Drill an oversized hole for the screws you will be using. Fill the hole with thickened epoxy, let harden and sand smooth. Now drill the proper size hole for the screws, dab the screws in 5200 and install. The epoxy incapsulates the hole and prevents water from getting to the core.
Alternatively, I have seen peopl mount a piece of starboard to the transom with 5200 and screw into that, to avoid drilling the transom.
