I'm already comitted to installing a B60 AirMar transducer thru hull but I've never done it before. the instructions are fairly straight forward. 1/16" bead of 5200 around the lip of the transducer and then cover the threads of the transducer the full width of the hull so that all threads fill in and create a seal between hull material and the transducer itself. Sounds simple enough.
Experience tells me there's always little tricks or techniques to make these kind of installations go smoother. Since its a hole in the boat I want to make sure I get any additional information necessary to have this go well. The boat is dry and won't see water for another 30 days or so.
From someone who had done this before, is there anything to watch out for or absolutely do (don't do) in this type of installation?
For what its worth, I found the original digital depth transducer that still works. I plan on leaving that in place and mounting the new one near it (left or right of it but not behind) as its an ideal place to clamp it down.
Thoughts?
Thoughts?
