Insurance Dilemma
glenncal1
Last weekend we launched the (new to me) boat turned out that the water strainer for the AC had cracked over the winter and the boat started to slowly sink as the incoming water was greater than the bilge pump could handle. To make a long story short I called Boat US who gave me the number of a local salvage co whoe sent out a van with extra bilge pumps, we de-watered the boat. When the level went down we could see that the strainer was cracked and we closed the thru hull. Went to the storage yard and got my trailer and as a precaution pulled the boat. Anyway no damage to boat, water did not get to engines and stayed in engine compartment.
The insurance company is denying claim as they would only cover damage to boat. I asked them (supervisor) "if the boat sank would you pay the salvage company to re-float it?" Yes. But by keeping the boat from sinking and saving them a much higher claim (damage, environmental, refloat etc. ) I am not covered. I said to the guy, financially I would have been better off to let it sink. Still no coverage. Needless to say I will be changing companies and asking some very specific questions of the next company.
Do you have a deductible? Does the deductible come close to covering the expense? If so you are ahead of the game because you won't have to make an insurance claim thus raising your rates.
Bruce-I would rather not say at this point, I still plan to write a letter etc. Also the claims adjuster and his supervisor I think did their best to see if this could be covered. It is a "flaw" in the policy. Unfortunately this "flaw" is going to cost me some serious bucks.
Tough one. Many of the poicies I have read pay out for these instances in relation to a "covered loss."
There isn't any damage to the boat so there is no covered loss. Very tough one. Write the letter, however. That action may pay dividends for you.
every policy i have seen says that the owner should take action to reduce damage. Stopping sinking sure seems to fall into that category. In fact the way I read that clause if you just stood by and let it sink they might claim you failed to take the required action and refuse the claim on that grounds.
what did it costs you to get the guys to pump it out ? if there is no damage and the water didn't get up to the engines, you don't have any or much damage...
call it a cheap lesson... i can't quite understand why you didn't close all the seacocks right away... that's the first thing to do in taht situation then check the most likely sources like stuffing boxes, etc... that' woudl have solved the problem with no expense.
lesson nr two is to have decent bilge pumps !! nearly all boats are delivered with insuficient bilge pumps... you should had a rule 2000 or ideally a 3700 in the engine room, higher than the primary pump so that it only comes on if the primary fail or can't keep up. first thing i did on the last 2 boat i bought was just that.. adding a 3700 !
