Interesting things at IBEX
I went to the International Boat Builders' Exhibition & Conference in Miami the other day and saw more than few interesting products. Below are some of them.
VEEM prop with the plastic inserts that can be used to change pitch without changing the blade itself. Color of insert denotes pitch change. First time I had seem them in person.
Very light prop with carbon fiber blades that can be replaced if damaged. Claims are a gain in over all performance due to much lighter mass to turn resulting in less load on engine. As well as little to no vibration if one or more of the blades are damaged. I would also think there would be less stress on your transmission when you shift due to the very low mass of these props. conturprops.com
Vetus anti-siphon gizmo for your fuel fill.
Deck fuel fill with built in digital fuel gauge.
Airmar transducers that have tiltable element so there is no need for a fairing block.
Very cool fiberglass mat that starts out flat like a regular piece of glass mat till you wet it out with resin. And then it expands on its own into a very light weight sandwich structure. parabeam3d.com
And just for fun, this:
Now THERE's an accident waiting to happen. I suspect that the wait will be short. Very short.
I don't recall the V8 powered "cart" being for sale. Just promotional. But I bet it's gotten away from some one in the company at least once. :-)
The composite props are really something. Wonder what those cost?
From an aerodynamic point of view those two props are interesting. The Veem prop is akin to raising the spoiler panels on a jet. While it will change the pitch, there is a drag penalty. I can't imagine a situation where the psuedo pitch improvement would result in improved performance. Rather, it seems to be a quick and easy way to make an adjustment without hauling or divers.
As to the composite prop, I think as long as you keep away from sediment and mineral laden waters you would be okay. The big problem with composite props and fans on airplanes is erosion from airborne dirt, even aircraft that spend a lot of time at altitude. I notice the lack of erosion stips on the leading edge. I don't know of any composite prop in the avaition industry that will last long without an erosion strip.
G-B, sounds right to me... though most in this neighborhood wear stainless props, those of us who ( usually ) avoid running through shoals and oyster reefs -still- have polished props, almost certainly due to the sand-mud-water slurry we run in. Ole Man Riber sure do belch an amazing mixture. ;)
I envy you guys who get all nervous in "only" 5 fathoms of water. I'd be down right beside myself if there were 15 ft of water to play in. ( usually a "good" channel has 6 ft, we will run through 3 or four feet without a worry. As long as you won't bury the hull if you drop of of a plane, it's good enough. )
Bill, funny you should say that. Most of my boating is on the east coast. I'm never comfortable until I'm in water a few hundred feet deep. I don't envy you gulf coast guys.
All that shiny stuff looks good on the counter.
Give it a week or two in salt water.
There have been some composite changable blade props for outboards for some time. They are quite flexiable, and subject to breaking. I am sure that these carbon fiber props are more durable--not sure about the flexing.
"The composite props are really something. Wonder what those cost?"
I was told approximately 25% more than standard props.
"I am sure that these carbon fiber props are more durable--not sure about the flexing."
I was told no flexing to speak of.
"As to the composite prop, I think as long as you keep away from sediment and mineral laden waters you would be okay."
That question I didn't ask. (But I will.) They appeared to have a heavy coating over the carbon fiber base layers.
Ask them if they plan erosion strips on the leading edges as well. I don't see how you can get away from that.
