- Jun 25, 2001
- 5084
- 67
I have a 2002 4.3 L MerCruiser with thunderbolt ignition and non EFI carburetor that I have been getting an intermittent stall either during a slow cruise or while in neutral. The engine just stops and almost appears like I flipped the kill switch. After a few minutes of trying to start the engine it would eventually start again and run fine. Two years ago the distributor, distributor cap rotor and sensor were all replaced as I cracked the distributer while putting in a new sensor due to no spark. This year I Replaced fuel seperator and plugs and still having issues. I was planning on replacing the coil next. Any assistance would be appreciated.
Thank you for your responses. Is there any documentation someone can provide that would show me how to either test the neutral start switch or the lanyard switch to determine if it could possibly be the problem?
