Internet access on the eastern seaboard
Well-known member
We hope to travel the ICW. I looked at the Sprint site for coverage and they are good except for the Carolinas and Georgia (Nationwide support that appears capped around 50-70KBS).
Verizon seems like it can do the whole coast but they have this 5G limit.
Has anyone experience with Verizon and what it means to have the 5G limit? We were at a buddy's house not long ago, and we attempted to play a slide show off the internet and it wound up capping the xfer to the point we had to give up.
The satellite systems are way too expensive since there is at least 2k in equipment and then they bang you for 100 bucks a month.
We currently use Road Runner and because of that we're spoiled so there is hesitation to switch Email again. But what are we going to do if we can't hitch hike on wifi? Get two ISPs?
That doesn't make much sense either.
Any input is appreciated.
From VZW site: "If usage exceeds 5 GB per line during any billing period, we reserve the right to reduce throughput speeds of any application that would otherwise exceed such speed to a maximum of approximately 200 Kbps. These speeds are subject to change, in our reasonable discretion, in order to address network issues."
I have over a dozen VZW aircards for my Navy support team that runs up & down site on the east coast and have heard no complaints when used
I also would recommend the Digital Antenna’s PowerMax 4KMR-30M(Got from BoatFix for less than $350) wireless cell booster/repeater system So far I have not gotten anything less than full signal strength regardless of where we are
Very happy with the setup
http://www.digitalantenna.com/prods/cellbooster_4KMR-30M_marinervrepeater.html
check cingular/att, i don't know how their coverage is in the carolinas but that's all i use and between the webcam and some website development, i use the internet a lot. no issues, with have G3 down here which is very close to DSL.
I use my verizon air card from VA to PA on a daily basis. Other than a few small "dead" spots in very rural areas on MD eastern shore I've had no complaints at all.
One item that Verizon and Sprint do not publicize is that they have had a data roaming agreement in place since last year. The sprint package is cheaper, and you get coverage wherever Verizon has the cover. I supplied Sprint service to a large government agency since Katrina and Rita and their staff had no coverage problems anywhere up and dwn the east coast from Maine to Florida.
But these days 5GB is chump change. I know people that pull 300MB a day. The problem I have with that is all of the "rich" text documents we receive. They chew up bandwidth in a hurry.
Andy are your folks using alot of rich text doc? PDFs etc.?
Sprint unlimited mean unlimited so there is not a 5GB limit even when roaming on Verizon.
I'd love to give Sprint a shot but there coverage map and the data rates they support in the areas I mentioned is really poor. That's what their coverage map implies.
The worst of this mess is that we will wind up having to buy wireless later on for about 6 months where we stop. Basically the new service covers us down the eastern seaboard for a month or so when we cannot hitch hike. But doing that will require a one or two year commit! Then we wind up having to purchase a wireless connection for 6 months on top of that, and we would have access to our road runner id anyway!
lanbuilder is correct. Sprint users can now roam on Verizon towers, but at the slower 1x speed (around 90-100k). lanbuilder is also right that Sprint does not cap usage. However, they do cap it if you're roaming a good bit. They've been said to then send a "thanks for your business, but we're dropping you" message.
I tether my Verizon phone for access via laptop a good bit. I've yet to go over 1 gig in a month (and that's with my Exchange Server e-mail going on 24/7). 5 gigs is quite a bit of data. And as Mike and a few others have said, if you're going with the data card route, you're most likely safe. Verizon really just wants to keep those who tether their PDA's from abusing bandwidth (like streaming Slingbox for hours at a time, every day of the week).
I do believe that other than the Sprint SERO plans, pricing for cards is the same for both VZW and Sprint.
I ditto Pascal. I have gone by water from Baltimore to Miami now with my AT&T 875U aircard with only a minor hiccup in a small area on the Pungo in NC. My Digital DA4000 Amplifier has had to be broken out twice to boost through-put speeds. Videos, big files, no problem. Verizon has done a great job building out their high speed network, but can't stand a lot of pressure put on it by consumers... their business and government customers need the bandwidth. The GSM technology used by AT&T has much more tolerance, but hey have been relatively wimpy on the high speed ("3G") build out. It does blaze here in So.Fla though.
George
Pfft, I tried using a cingular card in a laptop and the coverage on the Chesapeake was horrible. I've used a Verizon card in the same setup and had constant coverage. Never had a problem with bandwidth either and I've had some days where I hauled a practically a freight train of data through it. No slowdowns, no complaints from VZW.
Dan
We send everything you can think of! PDF’s are chump change
With email we often send PPT’s, VSD/VTX, MPP’s, DWG’s/DGN - some of these can get very large
My team also logs into internal web based CRM and Dev requests system all day long as well as SalesForce.com-BoaterEd/BoatFix :D
I would say that most of us go over 5G every once and in a while- with the exception of one guy roaming in Canada once we have never been hit with some over charge or known downshift of speed
We use CrackBerrys a lot for short mails etc…
We have other teams that use AirCards and CrackBerrys as well all over the US and Europe- we use only use VZW for the US based staff –
The other point here is that in the mean time, we both need access. That means we'd wind up doubling our cost by switching. All of these plans seem geared to a single machine. Is there an alternative or did I loose sight of an option?
These plans are expensive for what they offer without considering the mobility aspect. I just got off the phone with Verizon and for 60 bucks we don't get anything besides access, and even if I tether to the cell phone I wind up spending 60 bucks a month.
I thought I was on to something with Cruisenet (shakespeare promo) but this is merely a large expense for hardware that has to be backed up by one of these plans offered by att, sprint etc..
I will be trying the new Ericsson W25 unit on Cingular's network It does 3G as well as voice all in one box. It also has a 4 port router and 802.11B&G wireless. I use an external amplifier (direct connection type) and a digital antenna on the arch. I have tested Sprint and VZW and both work well in Southern N.J. I have tested both the Kyocera and LinkSys WRTG-54G routers with great success. I'll report back about AT&T/Cingular once I install the box and have time to test it against the other 2 carriers. The nice thing about the Ericsson box is it should roam in the Bahamas. Take care. Bill
Ask Sprint for a company discount if you are employed by a large company. Their usual rate is 25% off. Sprint also gives roaming at no extra cost in Canada and Mexico.
Sprint does not provide broadband in our area. Oh well. BTW Verizon's discount does not apply to broadband.
Does Sprint provide 1-RTT (voice/data service)? If they do your speeds would still be better than 9600baud on the satellite equipment you refrenced in your 1st post. Also your talking about traveling so the speeds would go up depending on the area you are in.
I've always assumed that data rates were going to fluctuate based on the signal strength. It's more a connectivity issue and single point of billing than anything else.
The question I am trying to answer is this; Is there a Wireless Broadband ISP that also provides email storage and servers? If so do they also provide land line, cell phone etc.. I'd like to have one bill at the end of the month not 3 or 4.
Verizon does not supply email. Sprint has no coverage in our area and we also need that to justify the switch from roadrunner. I doubt sprint supplies email. The last thing I want is a bill from sprint, road runner, and verizon.
For example, *IF* verizon were to supply an email id like they do for DSL, I'd jump from road runner. This way I can keep verizon wireless for the cells add in the broadband data, the landline, and dump road runner. But when we moved about 10 blocks to our current location from the old house, dsl was not available. 10 blocks.. DSL is everywhere but here. I still can't believe it.
No one seems to offer all of this because the business market offers them the ability to be less competitive on the residential end. Somehow I suspect that this will change in the future.
Once we settle down on the trip, we wind up getting wifi for under 100 bucks a month no strings for a few months. Maybe even free.
So for the sake of having access while on the ICW we get locked into a 2 year contract, and all we have in return is access. I'm thinking it isn't worth it since all we get is access. Sure I can see it for a business or if money is no object, but shelling out 1500 bucks over two years to back up a couple of months of access is ridiculous. Especially in light of all the hotspots that are around.
