If running on the generator is desired then you should also consider the load the battery charger will put on the system and if the battery charger can be throttled back.
If you have a 100 amp battery charger then it will draw about 14 amps off your AC line. If the reason you started the generator was to charge the batteries then that's fine, but if the reason was to run some high power device (microwave, water heater, stove, etc) then having the battery charger take 14 of your available amps (probably 30, but could be only 20) may not leave you with enough to work with.
I have the Xantrex inverter/charger and with the optional remote control panel I can throttle the battery charger down, a feature I use a lot.
Rod
