Is ANYbody Responsible?
Tanqueray
My Marina is about 1/2 mile up what I call a "Creek" off the local lake. The entrance to this "Creek" is marked every year in the spring by Red and Green Nav. Aides by the State which also maintains the Nav. Buoys on the lake itself. Puts them in every spring and takes them out every fall.
About 63 weeks ago we had some pretty strong Thunderstorms roll through the area and it took down a tree along the bank of this "Creek" which was the backyard of a house that has been for sale. The tree went almost all the way across the creek but left enough room to get a boat through although you did have to pass VERY close to the shoreline of the property across from it. Let me also say that this becomes tricky with a boat of any length because THAT house also has some docks extendeing out into the creek the majority of which are not maintained and falling apart and collapsing into the water and the ends of which are sometimes hard to see if the water is high or after a storm turning the water murky. Well this weekend when we left the Marina with my friend behind us in his Carver we noticed that this tree had now completely broken away from the base and was now more to the other side of the creek and the path past it was now even narrower and on the opposite side of the creek of where it"s been the past 3 weeks.
We made some inquiries and discovered that alot of the neighbors had been complaining about it to the town and the state and also tried to find the owners of the property of the house (For Sale) through the Real Estate Agency but got nowhere with any of them with the State and the Town saying that it wasn"t their problem. So we decide to see if the now narrower path is passable so I go through first because I can raise my drives. Guess what.........didn"t matter.........got as close as I possibly could to the shoreline and.....you guessed it....was in neuteral and tried gliding past the obstruction but the current stopped my forward progress and I had to put at least one engine in gear which I did only to be greeted by the unwelcome sound of the transom trying to hop up and down as the prop tried to make mincemeat out of the piece of limb of the tree wedged in the drives.
Hooked a line to the Carver and we pulled it into the Marina and into the Travel Lift and had it pulled.........pretty ugly to see your boat coming up out of the water with a tree growing out of the drives. Got it all cut away and now I have no forward on the Starboard side...Putting on another drive today.........
So other than my Insurance Company.....being that this IS a MARKED Channel off the Lake and the State maitains the markers..............is ANYbody responsible for the removal of this obstruction?
Depends on how bad you want to get by the tree. If it was me i'd grab my chain saw and spend 15 minutes. However "to each his own"
Seems everybody has to have everything done for them by somebody else. So hole up and wait while time and the season slip by.
I agree with Old Houseboater.
Grab a chainsaw and go to town.
Grab the Chainsaw is a good idea but the creek is about 20+ ft. deep and I don"t think Chainsaws were meant to work in the water not to mention that in itself creates another problem What to do with cut up tree. Can"t just let the pieces float around......and I don"t have the equipment nor do I own a piece of property with a shoreline on this creek to yank it out with.
A chainsaw will cut branches in the water. We use them up here in the winter to cut holes in the ice for fishing. You need to get an environmental group involved. That tree might be interfeering with the migratory and reproductive patterns of gawd knows how many endangered species! ;-)
Chainsaws work in water!
In Louisiana that 'tree across the waterway' is a way of life.
After every rain and almost every windstorm somebody had to clear a tree or trees from our creek or lake.
Dont wait for 'big brother' to get involved. Just do it!
Make sure you have a buddy with you and some lines to work with.
Dont have anyting in the boat you dont want to lose.
Once the big limb rolling over, caught the boat and took it under.
We lost the Chainsaw that time. It's still down there in the Mud somewhere.
If I had some good advice to offer, cut those big limbs off first.
You cant tell if the Cut-off part will roll in the up-stream direction or down-stream.
Always cut from the up-stream side, and have a line tied off to something up stream so you wont drift into the freshly cut wood that will be rolling as it goes on downstream. That way you can always find the boat if the Log takes it under.
Go have a ball. It's a fun project for a couple of guys.
If someone were coming up the Creek at night at a high rate of speed (it is 20 feet deep) and hit the tree, there would be a lot of damage to the boat and probably to any people who were in the boat. That would lead to an investigation. Go to the town hall tax office and you can find out who pays taxes/owns that property. Make a formal safety complaint. Write a letter to the newspaper or local TV news show. Make a stink. The squeeky wheel gets the grease, etc, etc, etc.
Excuses, excuses!!!
Adapt, improvise, and overcome. Chainsaws will work in water. For sure you are not the only effected by this tree, gather a working group and cut the damn thing up.
There are plenty of options. You could cut off the branches and tow the trunk to an area where you can drag it up on shore and finish the job. You could cut off the branches, use a few come-alongs and drag it back to the shore of the property that it came from.
Geez 63 weeks man - just get it done.
Yep, I agree, just do it!
Isn't it funny though, we have an old housebaot sunk near us in the Hudson. It's not in our way but we called the USCG, DEP, local village and nobody wants to take ownership. Where are all the tree huggers, river keepers now? What about the kyak groups and every damn municipality that "NEEDS" a police boat or fire boat? What about all those fees we pay to protect and maintain waterways?
Sadly, you're on your own....just do it. Tie a line, tow it into the marina and use the lift to remove it...can't be that hard.
Why not just get a heavy line on that tree, then use a come-along or somesuch tied off to a tree downstream to pull the thing over to the shore? If you get it moving, drag it out into the main body of water and then beach it out of the way?
"is Anybody responsible ?"
for the damage ? sorry but you are... :-( if you knew there was a tree in the channel then you shoudln't have tried to force the issue. is the water that murky that you coudln't see the branches 2 ft under the surface ?
I think the marina you are docking at shoudl be responsible for clearing the channel but if they won't then i would try to tie a line to the tree and tow it out of the way... you could just tie it up the old docks...
hoping the town or county or state or... will handle it is going to drag on forever...
Chain saw it and dump it on the lawn of the house from which it came or tow it into the broken piers and tie it there...
Of course, you could try to get a public authority to do it. Simpley go down to city hall with a wheelbarrow and get the required forms ( do NOT forget the environmental impact statement! ) Fill them out and wait.
I like that idea, dump it on the lawn of the house for sale. Perfect.
Can you post a picture?
When it comes to the government, nobody is ever responsible for anything other than making sure you pay your taxes on time.
Just got back.........Put the boat back in and got around it and pushed it onto the lawn of the property it came from. Got it close anyways and had my friend pull it up with his truck.
Good job! Like In The Know suggested, you overcame.
I kind of figured that"s what I"d end up doing anyways.....Just thought I"d run it past you guys to see what you thought. Sort of pisses me off though that there were several other boats coming and going (trying to at least) and just lined up and waited till we were done. Not ONE of those bas***** offered to help.
Welcome to the real world. There are doers and there are freeloaders. Too d**n bad the ratio is going to h**l.
