Winterizing your fresh water system (excluding A/C).
Drain main tank by opening all hot and cold water lines and flushing toilet.
Fill fresh water tank with 5 or 6 gallons (maybe more) of the pink environmentally friendly anti-freeze solution.
Open each hot and cold water faucet one by one and the transom shower until the pink stuff comes out, then shut them off.
Flush toilet several times until pink stuff appears in the bowl.
Shut off fresh water pump and vacuum pump for the toilet.
Is it as simple as that?
