you are not supposed to have wet cell batteries under an inverter? They were inside a high quality battery box, but the fumes might get out.
I understand the theory, but the Yacht Broker said the Surveyor was wrong.
I finally put AGM batteries in that spot. Still in the container. Does that pass the safety test?
He said we had delam wood/dry rot and our repairman cannot find it. It seems like the Surveyor used a Multi-Tester to check for wet wood, but I can't remember for sure. There were some wood shavings from an electric drill when they installed some items. Any ideas?
