Does a survey normally include the engine? I had a 27' power boat surveyed in RI and the survey guy said ahead of time he did not survey the engine or outdrive. I was pressed for a survey by a certain date and the marine surveyors were backed up. I had a mechanic run a compression test and I took an oil sample myself and sent it out and also measured the temp of each riser to catch anything that might show up.
