Is there a product?
I launched the boat last weekend. I have an abandon through the hull transducer that is now weeping about a few drops a minute. I tried 5200 on it but there is enough water seeping that the 5200 will not adhere to the surface to stop the leak. Is there a product that will stop the leak that can be used is a damp surface and ideally be removable so next fall I will remove the offending transducer and permanently patch the hole. Obviously last season it was not a problem or I would have taken care of it over the winter. Every product I look at recommends the surface be clean and DRY. Because of the weeping I can't keep it dry enough to put the product on so the result is it will not adhere or stop the leak.
Any suggestions?
Any suggestions?
