Jasper Motors?
I used a Jasper re-man 350 a few boats ago. I only kept the boat about two years fter the re-power but I had no issues with the engine. The warranty seemed to be good also.
I hear more good than bad about them - no personal experience
I can't speak for their marine engines but I have had numerous engines and transmissions installed in my company truck fleet and they are still running. I did have 2 warranty claims for transmissions and they stood behind them even though one trans was just out of warranty. I also had the performance division build me a 302&C6 trans for a 65 Mustang and that motor/trans is awesome.
However I did not choose Jasper for my repower. I installed new Mercruiser 8.1 HOs with Smartcraft system view 5000s.
My experience with Jasper engines was a nightmare. They would fail again within a year, and although the dealer/mechanic would replace under warranty, the boat would be down for weeks at a time. When I was underway again, the engines failed again the next year (again under warranty). The dealer said that there was an issue with quality control that Jasper had corrected, but I finally bit the bullet and repowered with new Mercruiser Bravo 3's. My life has been good ever since. One other note on the Jaspers. The dealer/mechanic had to battle with Jasper both times to get replacement engines at no cost. Jasper was not quick to acknowledge that their product was faulty.
Yes installed 6 of that 5 have failed 3 failed before install into boat (excessive vibration on the test stand ....wrong crankshaft)
no remans whatsoever only new replacements here..... not much dollar difference....boat gains value and replacing the old 260hp small block with a vortec 320-340 hp makes a huge difference have never herd of a reman staying together very long
I have replaced client engines with reman Jaspers; I recall very few issues. Recently I decided to use a local builder when time came to do one of my personal boats. In my opinion you have no flexablity on the build quality and parts with large replacement houses; so I looked something different. I don't real get impressed by automotive builders often but some people understand what it takes to make a strong marine engine. A four bolt main, Cheap parts and sloppy tolerances look the same under a new paint job. I used Cope Brothers in Tacoma WA, they have a 100% reliable track record with me over several jobs. Darin is the man, his brother Darick has acomplished nascar fame. Good luck
I will never, never, never buy another remanufactured engine, from any builder. Remanufactued engines have nearly ended boating for me, after getting three duds in a row from Recon. When looking at long blocks, the pricfe of new and reman is close engough that it doesn't make a lot of sense to go with reman. But if you can't get the money together for new, find a running take out that you can see run, test the compression and oil pressure, and if they are ok, buy it.
Looks like this is a split decision regarding replies. Here's one in Jasper's corner.
I had a Jasper reman installed on my last boat and ran it for two years with no problems whatsoever.
Buddy had very bad experience. Rebuilt jasper motor had a failure with in weeks of install . They refused to ship another motor and wanted to bad one back.. They rebuilt the bad motor .. took weeks to get it back... Then they only pay 65 per hour for warrty labor . So the customer had to cover the difference... AMAZING
I think Ms Robinson had a issue also from this site.
rob
Guess if you have to go with a reman... but seems brand spanking new marine crates are very reasonably priced these days... 350's anyway.. not sure what motor you're looking for.
In 2000 I used a Jasper longblock 454 for our SeaRay 290 Sundancer.
(original factory engine had 2 piece welded valves. A head had broken off a stem, bounced around in the chamber and tore things up pretty seriously. The stem got into the camshaft and 1/4 of it was destroyed as well, so no more Mercruiser blocks for me, thank-you-very-much)
The Jasper remanned longblock was better built in almost every way over the original Mercruiser 7.4l 454. Much better pistons, much better timing chain, heavier mains, and ONE PIECE VALVES!!!!
The only issue I had in dealing with Jasper was they sent the wrong engine initially but that was my marina's fault as they told Jasper the generation of my block wrong. Jasper was quite excellent about the screwup, had another longblock on the way the next day and picked up the wrong engine when they delivered the right one.
Now that was a few years ago that I dealt with them, but I was VERY happy with their product, their service and the quality of their block was absolutely better than the stock Mercruiser.
