I have given close-quarters instruction on a 210 SX, and find it to be quite controllable, given understanding of a few important handling differences from "traditional" boats.
1) There's no transmission. Being in or out of gear is not a yes/no proposition; it's more like a dimmer switch on a light. So, the shift lever is working, whatever position you have it in.
2) Neutral isn't neutral. Once stopped, to stay dead in the water, you must set the shift levers a little bit in "reverse."
3) Off-throttle steering is best achieved by using reverse gear, along with the steering wheel. Once those skills are mastered, close-quarters work can safely be done with no raised throttle.
