i am having a problem with an outboard it is model j200cxedr serial g04084181 johnson oceanrunner.The problem is as follows I try and start motor it takes forever when it finally starts it runs for a few minutes and stalls .I try pushing throttle when running it dies immediatly.I got it running and when it goes in gear it shuts off after awhile at idle and other motor running i shove in gear and she will run or shut down. When it is idling and staying on she runs smooth and then it sounds like cough and may stall.I have changed water seperator filter not the little filter at motor.I checked hoses and air vent good.I do have twin tanks and the one tank in front is always full back tank seems to be the only one used and tanks are tied in together do not get this help
