Just does not look possible
navman
to cross oceans like this. Took this pix with my little pocket cool pix camera this afternoon off our back deck. The port must be expanding again. Seen the same thing a few years back, it really does look cool close up but my pocket camera just cannot get there to see how odd this looks.
It's all about stability.
I have seen some pretty strange contraptions on barges that get
towed from the GOM to South America. The barges are smaller than
the modules footprints, but they tow them anyway.
Appears to be container cranes. They brought 2 into Mobile from China. Amazing!!
I saw a show on Discovery on moving some gentry cranes from asia to the gulf and it was awesome. How they do it amazes me.
MJK
Determination of verticale center of gravity (VCG) and conservative weather routing. Load, Stow and Securing Survey, that is what a real Marine Surveyor does. Actually this type of shipment is common now that China manufactures everything. Port container cranes were manufactured and built in American up to about ten (10) years ago. I sure hope Manitowoc stays around.
That thing must have ballast tanks all along her bottom. Looks like a job better suited for a catarmaran heavy lift ship. How about a mono hulled ship with folding armas, like polynesian canoes, for stability?
Just about all ships have double bottoms that can be filled with water ballast, or in some cases drilling "mud" (much heavier). Also heavy cargo can be placed low in the hold to lower the CG even more.
I think a trimaran would be too expensive and too specialized to be of much use, when you can do the same thing a lot more simply with a wide hull. Remember these are COMMERCIAL ships and they're expected to turn a profit.
These cranes are very stable as they stand. In normal useage, the container crane's grab must be able to fully extend to the outer end of the boom, pick up a fully loaded 45' container in the 80,000 pound range from the lower bowels of a container ship, lift the container vertically to clear the other boxes stowed on the vessel and then retrack the container to shore side and lower it onto a flat rack (container trailer) and repeat the entire process every four minutes or so. The biggest concern is the rolling of the vessel during transit. A 5 degree roll radius on the deck of the heavy lift ship transmitts to a 20 degree (or larger) roll radius at the peak of the container crane. The secret is conservative weather routing. I would quess that the trip requirements issued to the master prior to departure called for the vessel to avoid seas of 6' or greater and winds in excess 30 knots. This vessel is a specialized heavy lift ship and designed to carry odd ball loads, it is not some bulk carrier with a deck load. If the master used drilling mud for ballast, he would be looking for work some where else! It's hard enough to discharge sea water ballast in port now days much less a groundup barite soup with chemicals added.
Actually I've worked on several cargo ships that had drilling mud for ballast to offset the weight of a deckload of containers. It was "permanent", though, not something that was discharged at the next port.
My guess it's more common than you think; it's heavy and cheap, and can be pumped in.
Maybe they could some mud in the Delta to help us keep the waters navigable. Finding a place for the dredged mud slows down the permitting process big time. This would solve that problem!
In SW La., dredge spoil is now replacing erroded marshlands.
It replaced some billion dollar projects the US gov't had planned.
Remove it from the river and put it back where it came from.
Encountered this guy heading for the Hackensack River area
Then this guy telling me to stay clear,No kidding.
