Just Swing'en Away
marlinmikea
I have a '97 Carver 350 Mariner - flat bottom, no keel boat. This thing is SOOOOO FLATTTT the only thing keeping it from swinging around are the two rudders and I swear they're only about 4" wide :o)
Any ideas, other than a stern anchor, to reduce the swing while at anchor or attached to a buoy?
This last weekend while at my One Particular Harbor I hooked up to a buoy by putting my line through the eye and tied each end to the two cleats on each side of the bow alowing the line to slide through the eye (I know, chaffing) but that didn't help - and there was very little wind or current.
I was thinking maybe you know of something to throw overboard to reduce the swing. Just damn glad I didn't go in for a swim - it would have been fun trying to catch the ladder while it went by :o(
If you dangle anchor chain from the stern (no anchor attached) with several feet of it lying along the bottom it will help minimize the swing. If you add a small mushroom even better.
You could hang something in the water off the back to add drag. Or you could try making a bridle to tie the anchor line/chain off using a midships cleat. So the wind comes more on to one side then straight at the bow.
Dangle a bucket of water over the stern or off to one side if you need it out of the way.
A friend of mine would bring his bow line over to a side cleat to prevent swinging while fishing at anchor. It seemed to work really well, but did look a bit strange to others.
Spring the rode. A simple process of tying a line to the rode and a side or stern cleat. Adjust the spring so that the boat sits at an angel to the wind. Once it is far enough off center it wont blow back.
An alternative is to fly a big flag aft or anything else that will move the center of windage aft.
Effectively you have a box floating ontop of the water. It is going to 'sail'. Some good simple suggestions already starting with the fwd bow cleat, if you have one. It won't stop the tacking but it will tend to make the boat favour laying on one side.
Dragging an anchor/bucket off the stern will slow the tacking down too but there is the chance of being in the way of others if you are in a crowded anchorage & everyone is tacking, some more than others. When anchored the area 360 degrees around your anchor is not yours. Often boats swing over the top of anchors of nearby boats. It is no big deal. If you severely restrict your boat where everyone else is free swinging YOU are the source of the problem.
I tried the stern anchor method and it didnt help at all. The best thing I did was put up one side of the cockpit canvas to create a small sail. THat reduced the swing to tolerable levels, but it didnt stop it. Dangling weights off the stern didnt help. Maybe a short rode on a sea-anchor might work if you can keep it open.
Even using a bridle to 2 bow cleats can help "somewhat". As it starts to sail, tension is transferred to the downwind side.
Actually the swing starts from the BOW, not the stern. So if you can nail the bow down, the stern will just lay there.
The bridle is easiest but it's not 100%.
Springing off a stern cleat as Bruce describes works better.
A second anchor set off to one side (from the bow) better still.
IMO a stern anchor is trouble waiting to happen.
Thanks for the suggestions. There are a few things here for me to try next time.
New question but same theme so I won't start a new thread - What do you guys use for hooking onto a mooring buoy? There are many different detachable hooks out there - which one/s do you use and why?
Thanks in advance,
Marlin
Re the mooring bouy, I take it you are talking about the type with a ring at the top.
If you are real slick you can do it from the safety of your cockpit. Have your bowline already on the bit & run the end down to the cockpit, outside of rails etc. Come up to the mooring till it is next to your cockpit. Reach over, pass the line through the ring then as calmly as you walk down the aisle at West Marine, walk up to the bow taking up slack & pulling the mooring bouy with you. I pick up my mooring using this method in all kinds of weather in an area where moorings are very close together.
The Happy Hooker!
Liz,
I was looking at these while surfing on Sunday and couldn't figure out how THAT contraption could thread a line through an eye. But, after looking at it tonight I GOT IT!! Shove one end of hook through to close the gate - rotate - pull. Thanks!
If you are real slick you can do it from the safety of your cockpit. Have your bowline already on the bit & run the end down to the cockpit, outside of rails etc. Come up to the mooring till it is next to your cockpit. Reach over, pass the line through the ring then as calmly as you walk down the aisle at West Marine, walk up to the bow taking up slack & pulling the mooring buoy with you. I pick up my mooring using this method in all kinds of weather in an area where moorings are very close together.
Doug,
This is an excellent idea. On Saturday I backed up to a buoy and tried to get the admiral to hook it while I flew down from the bridge. She missed, I grabbed the hook and caught a slime coated leader rope with two floats on it. What a strain to pull the boat against the current and why does the wind always have to increase at these times!! With one end of the line attached it would be like you have some leverage - like pulling from the middle of the line instead of pulling from the end.
Thanks for the ideas - I'll master this yet.
On the swing... I find if I have a ton of rode out, I'll swing more. Sometimes I'll set it at 10 to 1 in a shallow anchorage then choke it back to 5 to 1 and swing far less. However, I only shorten the scope in 3 or 4 familiar areas where I know I have good to great holding. Would never do it in a new to me spot or on hard bottom. Wouldn't be able to sleep-
Mooring balls, we do the same as Veebyes (we never use their penant):
