Keeping the outdrive clean.
zeezer
This new boat is the first one that we will be keeping in the water (Great Lakes) for the summer. I had either trailered or rack stored other boats in the past except one which was in for one season only. My question is, what have you found to be the best method for keeping the outdrive clean? One inexpensive trick that I used in the past was to spray down the drive with Future floor wax. I was always careful not to get any on the zincs or on the lift cylinder shafts. It would have some algea at the end of the season, but would come spit shine clean after cleaning it up with Westly's bleech white. Hardly any scrubbing at all. The algea would stick to the floor wax & the bleach white would break the wax free from the drive. Any comments?
Sounds like a pretty neat system you've developed. I think getting your outdrive antifoul painted is a waste of $$$$$. Do you have access to both salt and fresh water? If so, run the boat for about an hour into each type of water. You'll be amazed how clean it will get! The salt water kills what grows in fresh water and vise versa.
Or store the boat on a lift between uses.
