OK, some of you are going to have a good laugh, but here was todays newbie adventure. After a nice day anchoring out, it was time to head home. Start port engine. Start starboard - whoa, nothing. Did the typical guy thing - turned the key harder - and heard a snap and it rotated within the switch. Couldn't get it out. Now is when I get my head out of my butt and notice that the throttle is slightly out of neutral. Apparently not enough to give me the warning tone you usually get when you try to start it that way. I place it fully in neutral and lo and behold the engine starts. Pop her into gear and off we go. So I'm about halfway home when it hits me - I'm not going to be able to turn off the engine. Worse, when in neutral the starter engages and grinds away.
Looking for feedback on whether my solution to the dilemma was the right one. When I got back to the marina, I did donuts at idle speed outside the entrance while I removed the dash panel and disconnected the switch. Was more comfortable doing that than going into the engine compartment with motors running.
Getting into the marina and backing into the slip on one screw was much easier than anticipated (even without power steering). I was able to wrestle the key out with channel locks, but I'm sure the switch is ruined.
Is it going to be an issue matching a switch to the old key or will I color coding the new one?
