Kohler sdmo Generator volvo engine
bigrellz
New member
Kohler sdmo volvo engine had run out diesel but now its just cranking D9A2A 7009177165 can any assist me please.
Not familiar with that specific gen. But if it ran out of fuel it needs to be primed as both the racor and the secondary filter will be dry
If that model uses an electric fuel pump, turn the key or run switch on and let it run a few minutes. Then try starting it
Or if it has an external priming pump, use that
It's a 300kva also it had a code saying check fuel level dipstick kolher sdmo 300kva
Perhaps the more relevant question would be why ask such a question about a gen set that it seems Kohler does not advertise for marine use.
Just curious :)
