Kudos To ACR Electronics
After going through our ditch bag in preparations for heading to the Bahamas and then points South we realized our ACR ditch bag had frozen up zippers and the ACR SOS spotlight battery holder was bad. Called them up about buying replacements and they told us to "Stop by and pick up new replacements of each free of charge.".
That is great customer service.
I am happy with my ACR spotlight. The company makes some good products. I have their 80,000 candle power spotlight and love it. Many spotlights have more power but they are one of few that only tilt the inside reflector up and down instead of the whole upper housing. It was twice the money but it has gone seven years so far without issues. I later noticed that they have come out with a head tilting unit at a cheaper price to compete with the entry level market. I back a company that keeps a good quality product - if they have an entry level line that is made cheaper to compete in the market place that is fine, but keep the quality line to give us a choice. I'll pay more $$$ for a product that will go the distance. ACR got my vote thus my dollars.
Needed a replacement antenna for my EPIRB. I called and talked to them on Monday. They said they need model number, serial number, etc. I emailed that info to them on Tuesday. The new antenna was at my house on Wednesday. Incredible.
Forgot to mention - not a single penny of charge.
Just happened by this thread, and thought I'd mention a problem I have with my ACR URC-100 (with RCL-100 Point Pad). The vertical adjustment is no longer functional. Everything else works fine. I don't run much at night, so I don't know how long this has been a problem.
Any suggestions for trouble shooting?
Could be the controller or it could be the motor on the light. You'll just have to have them tested.
My model is smaller and the install manual is on the boat. Do you have your install manual? My point pad is hooked up to a control box up near the spot light. A coax cable comes from point pad to box then exits to the spotlight with multiple color wires. Each wire color controls a function of the light. Find out which colors run the "up" function and "down" function. Have a helper push the point pad while you check with a test light to see if power is coming out of box. If it is then take apart lens/bulb to check for corrosion, jamming, loose wire contact connection. They probably use the same control for many of their spotlights so wire coding is probably same as mine. If you cannot find manual on line let me know and I will find out color coding on my spotlight. Good luck -John
From what I read above, and from similar experiences I've had with ACR - my suggestion is to call ACR!
I've got the URC-102 Master Controller. The red wire controls "up" and the white wire controls "down." I'll probably have to contact ACR to find out what voltage and/or resistance readings (w/respect to ground) I should be getting, then wait 'till my next trip to the storage marina to troubleshoot.
I'll definitely check for corrosion.
I appreciate the comments, guys.
