Your situation may provide the proper signal and with no interference. If there was an issue with your dish you can go back to Sea Ray in this case. I would prefer to use the manufacturer recomendation, especially when installing it yourself. At least this way you will not void the warranty if installed according to the manufacturer specification.
When I was planning my purchase and installation all manufacters stated that the dish should not be near the radar do to the microwaves emmitting from the array which can cause damage to the electronics (on the dish)over time when both are operating at the same time. Also your radar can be blocked from receiving data. Below was information pertaining to my Sat Dish. Here is a picture of my set up with my custom mast I designed.
Page 5
DOME LOCATION
1. Select an area on the vessel for the dome unit, keeping in mind the coax cables will enter
the vessel through the surface directly beneath the dome unit. Use the following criteria:
a) The shortest distance between the dome unit and the main satellite receiver is most
desirable.
b) The dome unit requires a 16.5” (model
1500-HD) or 20” (model 1800-HD)
diameter mounting area on the vessel
surface. You may also use an industry
standard mount. (Call King Controls or visit
www.kingcontrols.com for more information.)
Exact hole spacing is shown at right.
Distances are to centers of holes.
c) The dome unit should never be mounted so that it is tilted more than two degrees
in any direction.
d)
Keep the dome unit as far away from the radar as possible, and if possible above
the level of the radar.
e) The dome unit should be mounted as close as possible to the center of the vessel
(fore-aft and side to side).
f) The mounting surface must be strong enough not to flex under the weight of the
unit or from vessel vibrations.
g) There must be no “line of sight” obstructions from this location. Items such as
masts or radar antennas that are too close to the dome unit may prevent the
satellite signal from reaching the dish (Fig. 5).
Fig. 5
