lorimccrea
- May 11, 2011
- 32618
- 2
Hi everyone. We are new boaters/owners of a 1988 Carver Voyager 2827 and are having leaking problems with both the depth finder and the speed sensor transducers. Has anyone had to either re-seal or replace the depth finder and speed sensor transducers on a late 80s Carver Voyager? We are planning to have the boat pulled next Friday and our plan will be to just reseal them if possible since they are working fine, but if there is something else wrong we will need to have new parts on hand while the boat is out for the weekend. I believe these to be original or near original equipment. The electronic pad on the flybridge says they are Impulse XP. It is just an analog read-out. The speed transducer has a wooden paddle wheel on the bottom of the boat. On the inside of the boat there is a piece of wood about 1 inch thick with a large washer and nut on it with the transducer going through the center. It is leaking at the top of that wooden block right at the washer. The depth finder has a triangle looking piece of wood on the bottom of the boat and a puck style piece of wood under the plastic housing of the "pig ear-style" transducer inside the boat. Are there gaskets on these transducers? I am thinking if we can just re-seal the current transducers we will still need to get some sort of new fairing block for inside and outside since it is pretty degraded. Should this be wood or some other material? If anyone has replaced with newer style equipment I'd be interested to know what you used. We are trying to stay cost effective here. Any replies would be appreciated!
