boating_rob
- Jun 19, 2006
- 21873
- 1,090
I hear you and agree with the LED should be high quality. but at ~$700 for a mast head light I can get a generator and recharge the batteries plus other things.
Originally posted by jbacchi
I replaced all of my cockpit and nav lights with LED's from superbright led. My only concern is the green nav light looks more tourquoise.
Is the LED white or green. If green, could the two different color wave lengths (lens and LED) be causing the difference?
Just a thought.
Sorry Bob but you are I assume talking about a Honda generator which I do not consider a marine generator and I would only use one in an emergency.
I could never sleep with a gas generator running not even my Kohler Low CO unit. Thank God I am converting to diesel power this season but even then I will keep my existing marine grade CO detectors in every room of the boat and 3 under the floor of the boat that are hooked to 2 separate alarm panels.
Just a thought.
The led is white and the lense is green. The white is so white that it washes the green a little. It's not a biggie but something I thought I should mention since people are talking about coast guard approved etc.
Originally posted by Robyns Nest
If you buy the 'Warm white' version instead of the 'cool white' LED you will have the same color as standard incandescent bulb for your colored nav nights, just brighter.
Look at this link, it shows the difference.
http://www.superbrightleds.com/carbulb-notes.htm
