LED Lights Red or White
boating_al
Got a question…I'm thinking of replacing my standard bulb lights with LEDs, but was wondering if I should get them in Red or in White. I was thinking that Red may be better on the eyes and still give enough illumination.
Al
Red. Nothing but red in Navy vessels (common areas, passageways, bridge...) after darken ship for just that reason.
LED's are so bright, you may have to diffuse them with wax paper on the lens.
According to current studies, blue-green has a slight edge over red for saving your night vision. You will see blue green often on illuminated controls. Red light is very nearly as good, but your eyes do a better job of seeing edges and lines in low light with red than they do with blue-green. That's why the Navy likes red lighting for saving night vision.
Why not use a combination? I use white LEDs for areas that need critical lighting and color rendition. Ever try to read a standard nautical chart with red light? If the white light level is low enough, you won't do that much damage to your night vision. I use white flourescent standard light bulb replacements when I need a lot of light. I've replaced incandescent festoon bulbs with white or red LEDs, and use red LEDs for safe, night vision saving courtesy lighting.
The colors used on charts are used for the reason that they show up well under red lights.
"Here's a quote from
USAF Flight Surgeon's Guide: Chapter 8
(about 2/3 down the page under the heading "Night Vision")
QUOTE:
Enhancing and Maintaining Dark Adaptation: For maximum utilization of scotopic vision, 20 to 30 minutes are required, in total darkness, to attain satisfactory dark-adaptation. A more practical alternative is to have the aircrew members wear red goggles to facilitate dark adaptation. Red goggles can be worn in normal illumination and do not interfere significantly with the ability to read maps, charts, manuals, etc. They block all light except red light, and red light does not simulate the rods, as we have seen.
To understand why red filters can be used to achieve dark adaptation, it is necessary to examine the relative positions of the photopic and scotopic sensitivity curves in Figure 8-20. If a red filter with a cutoff at about 650 nanometers is worn, essentially no light is transmitted to the eye that can stimulate the rods. However, the cones are sensitive to the red light, and, thus, adequate visual acuity is permitted. By wearing red goggles for 30 minutes, the rods are almost fully dark adapted. Although the cones are not dark adapted, it only takes about 5 to 7 minutes, after a pilot steps into the dark, for the cones to adapt. Cone adaptation is relatively unimportant, since they are incapable of functioning in starlight illumination. There are, however, some drawbacks to wearing red goggles. For example, when reading maps, all markings in red ink on a white background may be invisible. In addition, red light creates or worsens near point blur in the pre-presbyopic or presbyopic pilot, as red light comes to a focus behind the retina and requires more accommodation to bring it into focus.
Dark adaptation of the rods develops rather slowly over a period of 20 to 30 minutes, but it can be lost in a second or two upon exposure to bright lights. The night flyer must, therefore, be taught to avoid bright lights. Also, the instrument panel must be kept illuminated at the lowest level consistent with safe operation, and the flyer must avoid looking at flares, after-burner flames, or gun flashes. If light must be used, it should be as dim as possible and used for the shortest possible period.
Dark adaptation is an independent process in each eye. Even though a bright light may shine in one eye, the other will retain its dark adaptation, if it is protected from the light. This is a useful bit of information, because a flyer can preserve dark adaptation in one eye by simply closing it.
Cockpit Illumination: The use of red light (wavelength greater than 650 nanometers) for illumination of the cockpit is desirable, because it, like red goggles, does not affect dark adaptation. Red cockpit lighting has been traditional since World War II. The intent was to maintain the greatest rod sensitivity possible, while still providing some illumination for central foveal vision. However, red cockpit lighting did create some near vision problems for the pre-presbyopic and presbyopic aviators. With the increased use of electronic and electro-optical devices for navigation, target detection, and night vision, the importance of the pilot's visual efficiency within the cockpit has increased and new problems have been created. Low intensity, white cockpit lighting is presently used to solve those problems. It affords a more natural visual environment within the aircraft, without degrading the color of objects. Blue-green cockpit lighting is used in aircraft in which night-vision devices are used because, unlike the human eye, these devices are not sensitive to light at that end of the visual spectrum. In addition, blue-green light is the easiest for accommodative focus and is seen by the rods more readily than any other color. It is not seen as blue-green, however, but only as light. However, the enemy can easily see a blue-green light, under scotopic conditions, in any position of his peripheral field, whereas a low intensity red light would be invisible unless viewed directly.
UNQUOTE"
I changed every light and fixture in my boat to LED. It is important that the navigation fixtures be certified I used Aqua Signals 32 series navigation LED fixtures they exceed USCG requirements and meet the standard ABYC A-16. My gooseneck reading/chart lights are red or white. My salon ceiling lights are red or white, the salon recessed decorative lights are white and my floor courtesy lights are white. I had a total of 46 lights that were changed excluding the 5 navigation lights. My old current draw with the boat lit up was almost 20 amps. Now the current draw is less than 3 amps. This is a huge improvement in my effort to save Amp hours on my boat. The head is another place to reduce power consumption but this thread is about LED lighting.
Regards Bill
For a 24 foot express cruiser--go for white lights. If you have a pilot house boat, then I would go with dim red lights for running at night. Bright white lights, which are dimable, or both dim and bright white lights for at anchor or the marina.
Well, I've wanted an excuse to pony up for a good white/red chart light. Now I have my excuse.
Red lights on anything while running. Chart plotters are bad for blinding you too.
...or wear a patch over one eye like the pirate you are...[:P]
I'd never argue with the NAVY or the FLight surgeon over light colors n' such......but...
When flying at night I was always botherd by those Red lights. Somehow I never could see as good as I needed.
I'd have to sneak my tiny flash light out.
Maybe I was one of those 'pre-presbyonic' guys he's talking about. Although I'm still not color blind.
If you use that small LED penlight, you have to face the fact that your eyes take a while to adjust to the dark. But they do adjust. You learn tricks like memorizing points of light before you look down etc.
I like the Blue/green or Amber suggestions. I never had the chance to try that stuff though.
If your not going really fast at night its not critical anyway.
If you need night vision quickly, pick up your binoculars. They collect a lot of light and will help you see whats out there right away. PS: on those Binoc's, 7X35's are optimum.
Originally posted by Billylll
I changed every light and fixture in my boat to LED...
Regards Bill
Where did you get them.
